Suspension & Brakes Theory, alignment, spring rates....
Koni Yellow's into a '00 Sir
Old Mar 30, 2008 | 02:28 PM
Piping civic's Avatar
Default Koni Yellow's from a EG into a '00 Sir will it work?
Hey guys I have a EG hatch with koni yellows not many km's on them at all. Hatch busted out on me and i was wondering if I can use my koni's on my new SiR?
thanks everyone!
Modified by Piping civic at 3:48 PM 3/30/2008
Modified by Piping civic at 3:55 PM 3/30/2008
Old Mar 30, 2008 | 03:50 PM
Targa250R's Avatar
be professional
Default Re: Koni Yellow's from a EG into a '00 Sir will it work? (Piping civic)
Yes, but you'll need spacers for the rear lower mounts. Some steel collars or several thick washers should do the trick.
Old Mar 30, 2008 | 03:55 PM
bmoua's Avatar
Default Re: Koni Yellow's from a EG into a '00 Sir will it work? (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">Yes, but you'll need spacers for the rear lower mounts. Some steel collars or several thick washers should do the trick.</TD></TR></TABLE>
washers do the trick...
Old Apr 2, 2008 | 03:33 PM
Default Re: Koni Yellow's from a EG into a '00 Sir will it work? (bmoua)
thanks guys, what is a good size washer to use and will this effect the shock in anyway? meaning would i just better to try to get a deal on a new set even though these are only a year old?
Old Apr 2, 2008 | 04:41 PM
bmoua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Piping civic &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys, what is a good size washer to use and will this effect the shock in anyway? meaning would i just better to try to get a deal on a new set even though these are only a year old?</TD></TR></TABLE>
http://home.earthlink.net/~civ....html
bring the bolts with you and test which washers fit.
Old Apr 5, 2008 | 01:24 PM
oh i see so they will fit on the front no problem but its in the rear where the problem is. They will still fit but it is a bad camber issue if i don't use these washers? would i be better off on getting somthing a little better for a set up?
Old Apr 5, 2008 | 01:31 PM
Targa250R's Avatar
be professional
He posted the wrong link; ignore everything you read there.
It has nothing to do with alignment. The rear damper fork is simply too large to fit tightly over the control arm bushing. It leaves a significant amount of space on each side, which can cause undue stress on the mount bolt and may make a lot of noise over bumps.
Old Apr 6, 2008 | 01:49 PM
clem kevin's Avatar
use spacers, i did this because my new LCA's bushings were to narrow, seems fine to me
Old Apr 12, 2008 | 12:10 PM
Default Re: (clem kevin)
thanks guys... i am get mixed emotions about this and i'm thinking i might just have to bite the bullet and buy some new ones! car is mainly for street and maybe the track a time or two thru the summer.
93SIRII
Feb 7, 2009 06:45 PM
DFW
Suspension & Brakes
Oct 29, 2006 11:39 AM
Tippyman
14
Oct 29, 2006 10:21 AM
johnzm
Suspension & Brakes
Feb 8, 2006 11:29 AM
da'ee
Feb 11, 2005 03:31 PM
