HELP: Cluster problem, no gauge movement?
Old Mar 30, 2008 | 02:11 PM
DoWnfall's Avatar
Default HELP: Cluster problem, no gauge movement?
recently i had taken out my dash to fix a leak problem in my 92 cx, now since i put it back in my cluster will only light up none of the gauges work
heres some random things to help anyones diagnosis
-all gauges are at minimum gas,tach,mph,temp
-the light for SRS, brights and battery are the only ones that light up
-no check engine light or seatbelt light (have the cel switch set up from the diy one and neither switch position lights it up)
-ive checked the fuses for cluster and stuff but not blown dont have my fuse roadmap for inside the car so the ones ive checked are all there/working
any help or pointers is greatly appreciated
the entire interior is from my older si so its been out before and i had done the replacement so i dont see how it broke maybe i knocked something loose
Old Mar 30, 2008 | 03:32 PM
DoWnfall's Avatar
Default Re: HELP: Cluster problem, no gauge movement? (DoWnfall)
bump?
Old Mar 30, 2008 | 03:44 PM
Former User's Avatar
Have you double checked that connectors A and B are firmly seated?
Also double check that fuse 15 isn't blown.
Old Mar 30, 2008 | 05:30 PM
Mike
Default Re: HELP: Cluster problem, no gauge movement? (RonJ@HT)
Also double check when disconnecting the plugs you didnt strip the copper off where the plugs are seated. I did that and my turn signals didnt show up.
Old Mar 30, 2008 | 05:37 PM
DoWnfall's Avatar
Default Re: HELP: Cluster problem, no gauge movement? (Mike"IAMSLOW"Myers)
my turn signals dont work either, ill check the copper tomorrow when theres light up for now i have to goto bed for work, ill dick with it a bit till i get tired
Old Mar 30, 2008 | 05:57 PM
slacks's Avatar
fuses
Old Mar 30, 2008 | 08:14 PM
Mr Marcin's Avatar
Default Re: HELP: Cluster problem, no gauge movement? (slacks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slacks &raquo;</TD></TR><TR><TD CLASS="quote">fuses</TD></TR></TABLE>
Yup that sounds right
Old Mar 31, 2008 | 08:12 PM
DoWnfall's Avatar
Default Re: HELP: Cluster problem, no gauge movement? (Mr Marcin)
oddest thing ever, took out my entire dash today with a friend of mine, we couldnt find any blown fuses, no disconnected wires. so we disconnected everything turned the car over once then plugged it back in and some how every thing worked.
i tried the same exact thing with unplugging about a week ago and no success but driving with no dashboard for a week some how helped? thanks to all cause i found a blown fuse for the sunroof from my si interior that isnt even in the box anymore
Old Mar 31, 2008 | 08:18 PM
Mr Marcin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DoWnfall &raquo;</TD></TR><TR><TD CLASS="quote">oddest thing ever, took out my entire dash today with a friend of mine, we couldnt find any blown fuses, no disconnected wires. so we disconnected everything turned the car over once then plugged it back in and some how every thing worked.
i tried the same exact thing with unplugging about a week ago and no success but driving with no dashboard for a week some how helped? thanks to all cause i found a blown fuse for the sunroof from my si interior that isnt even in the box anymore </TD></TR></TABLE>
wow that is really weird
GroundZer0 336
Jun 26, 2010 07:02 PM
ltran82
Nov 1, 2007 12:58 PM
djeclipzjv
Jun 16, 2006 11:11 AM
dpine
Dec 11, 2005 08:59 PM
Taikonaut
Sep 27, 2003 07:46 AM
