transmission rebuilding/gear swap question
Old Mar 30, 2008 | 12:29 PM
flatblack-h22's Avatar
Default transmission rebuilding/gear swap question
i have a b16 transmission that didnt go into 3rd most of the time. brought it to a friend shop and open it up, and see that the ring that goes around the gold syncro piece was broken and stuck to the magnet inside the tranny.
then i bought a complete gsr gear set to replace the broken piece and swap out the b16 4th/5th for the gsr 4th/5th. i used the b16 mainshaft and swapped out the b16 3/4 and replaced it for the gsr 4/5.
for the countershaft, do i use the b16 or gsr? and if i use the b16 countershaft, what all do i have to do? take out the b16 countershaft gear 4/5 and use the gsr 4/5?
also, about the shift fork, i can wiggle it around a bit, is that normal? or should i replace that also.
tia!
Old Mar 31, 2008 | 06:33 PM
Default Re: transmission rebuilding/gear swap question (flatblack-h22)
Tkthedk
Transmission & Drivetrain
Oct 14, 2011 02:06 PM
ashb82
Aug 15, 2011 02:28 PM
slostjoe
Oct 12, 2010 02:19 PM
EfSedanLove
Jul 22, 2009 05:25 PM
96 GSR-T
Dec 24, 2007 10:26 AM
