attn comptech rear swaybar owners!
Old Jul 9, 2002 | 07:43 PM
purplehazek4's Avatar
Default attn comptech rear swaybar owners!
does the rear of the car make weird noises with the sway bar on?
Old Jul 9, 2002 | 07:44 PM
Mike P.'s Avatar
25 Year Member
Default Re: attn comptech rear swaybar owners! (purplehazek4)
...only if it's incorrectly installed, or improperly lubed.
Old Jul 9, 2002 | 07:45 PM
seano's Avatar
Hey, are you running Nitto 505 tires?
Old Jul 9, 2002 | 07:47 PM
Mike P.'s Avatar
25 Year Member
Default Re: attn comptech rear swaybar owners! (seano)
Those are Bridgestone RE730...an excellent tire, by the way.
Old Jul 9, 2002 | 07:49 PM
seano's Avatar
Default Re: attn comptech rear swaybar owners! (Mike P.)
Thanks! I am researching new tires, and don't want to litter the board with more "which tire is best" post.
Old Jul 9, 2002 | 09:16 PM
TurboBumblBee's Avatar
i would also recommend the re730's.. great tires.. nitto tires have a bad treadwear and wear down fast.. if you havent upsized w/ your nitto tires i would go w/ a bridgestone re730's 205/50zr15
Old Jul 9, 2002 | 09:50 PM
Halo's Avatar
Default Re: attn comptech rear swaybar owners! (95CivicEX)
what setting do you set thse to for street driving?loose?medium?or hard?
Old Jul 9, 2002 | 09:52 PM
Default Re: attn comptech rear swaybar owners! (Halo)
the bar is set at medium and these tires are probably the best tires for the $ and ive tried a lot of tires
Old Jul 9, 2002 | 11:13 PM
bretx0r's Avatar
i have it, and you gotta put teflon tape between the rubber and the sway bar and it wont squeak at all
Old Jul 9, 2002 | 11:19 PM
NiiS's Avatar
Default Re: attn comptech rear swaybar owners! (bretx0r)
teflon tape
Old Jul 9, 2002 | 11:51 PM
Mike P.'s Avatar
25 Year Member
Default Re: attn comptech rear swaybar owners! (sinister)
teflon tape
plumbing supplies
Old Jul 10, 2002 | 08:00 AM
RokketRide's Avatar
I wore through the teflon tape and it started to squeak. I installed grease fittings, now I just give it a little squirt
Old Jul 10, 2002 | 08:23 AM
Default Re: attn comptech rear swaybar owners! (RokketRide)
actually its really not sqeeking, its more of a creeking noise
Old Jul 10, 2002 | 08:37 AM
eccentric.ek's Avatar
looks good though
Old Jul 10, 2002 | 09:46 AM
ESCALVANTE's Avatar
My car squeeks like a MOTHA!!
Is there any way to lube the fittings without taking the bar off?
Also, other than the noise, are there any other negatives? In other words, will the fittings get damaged if they aren't properly lubed?
TIA
Old Jul 10, 2002 | 09:51 AM
_unknown_'s Avatar
Default Re: attn comptech rear swaybar owners! (ESCALVANTE)
If the swaybar is creaking then you should look to see if the d-brackets are loose. Mine would loosen up and that is when the creaking would start. I bought some locking SS washers to go bolts that attach the d-brackets to the lower tie bar and I haven't had any noises since!!!
hth
Old Jul 10, 2002 | 11:45 AM
Viorent GRIP!'s Avatar
dude you seriously can't take pictures
[Modified by Mr. Shin, 8:45 PM 7/10/2002]
Old Jul 10, 2002 | 01:55 PM
ESCALVANTE's Avatar
Default Re: attn comptech rear swaybar owners! (garth)
When ordering your D-brackets, you probably got the lucky pack!
I have a '92 Civic VX with the US ITR rear Swaybar mounted with the Prothane and Beaks Kit. I have tightened the Prothane D-brackets twice now and it never resulted in a quieter ride.
I've checked the bushings to see if they were out of grease but they seem fine. I guess I just got the noisey kit. What do you guys think?
Old Jul 10, 2002 | 02:31 PM
PSU's Avatar
PSU
formerly DxHatchback
i like that tie bar. how much was it?
Old Jul 10, 2002 | 02:33 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
it`s normal. just need some lube.
Old Jul 10, 2002 | 02:35 PM
Dodger2940's Avatar
Default Re: attn comptech rear swaybar owners! (DxHatchback)
Its a Combo. Swaybar+ tie bar. I got mine for 300
Old Jul 10, 2002 | 02:40 PM
racecarpete's Avatar
Default Re: attn comptech rear swaybar owners! (Dodger2940)
... I got mine for 300
where did you get it for that price? i want one too!!!
Old Jul 10, 2002 | 03:00 PM
Dodger2940's Avatar
Default Re: attn comptech rear swaybar owners! (SilverCivic2k)
Modacar.com
It was 300 not its 369
Old Jul 10, 2002 | 03:21 PM
RokketRide's Avatar
Got mine for $260 direct from Comptech
Old Jul 23, 2002 | 04:16 AM
EKB18BPR3's Avatar
Default Re: attn comptech rear swaybar owners! (Mr. Shin)
"dude you seriously can't take pictures"
haha
