O2 Sensor question?
Old Mar 30, 2008 | 10:20 AM
xxmikeyxx's Avatar
Default O2 Sensor question?
Hey so i try searching on o2 sensor for the rsx but i can't seem to find anything having to do with the question im looking for. Rsx we have has a bad prim. o2 sensor i was wondering if i could swap it out w/a k24 o2 sensor? Or are they different?
-Thnks
Old Mar 30, 2008 | 10:29 AM
Tyte-S's Avatar
Default Re: O2 Sensor question? (xxmikeyxx)
I would imagine because of the larger displacement in the 2.4L, this wouldn't work. Just my .02.
Old Mar 31, 2008 | 01:14 PM
Perfectionist's Avatar
The O2 sensor element is essentially the same for all types. The difference is in the wiring... heated vs non-heated, etc. So, if the plug fits, it should work.
Old Mar 31, 2008 | 01:23 PM
Tyte-S's Avatar
But as the exhaust flow would vary from each car, wouldn't that cause the o2 sensor to burn out prematuraly? I thought that's why they make them for each car. If every car could use the same oxygen sensor, why not just have one universal o2 sensor?
Old Mar 31, 2008 | 01:35 PM
Default Re: O2 Sensor question? (Tyte-S)
O2 sensors probably get contaminated more often than "burning out". Electrically they are similar in function, but there are newer wide band sensors that are used by some manufaturers. Early O2 sensors relied soley on the exhaust heat to get them hot so they could operate. To speed up the heating and reduce emissions sooner, manufaturers added heater circuits to the sensors.
There are physical differences in the "packaging" of the sensors. For example, a Bosch type generic is surrounded by a cage that is not as open as the OEM type. Some generics come with wire pigtails you need to connect to the stock plug.
So again, if the physical size is similar and the connector fits, it should work fine.
Old Mar 31, 2008 | 05:07 PM
Tyte-S's Avatar
Default Re: O2 Sensor question? (Perfectionist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist &raquo;</TD></TR><TR><TD CLASS="quote">
So again, if the physical size is similar and the connector fits, it should work fine.</TD></TR></TABLE>I agree with this. Although I still believe it will "burn out" faster being it is from another car. Maybe K series to K series will be fine though.
phoshyzzle
Oct 18, 2009 07:52 PM
