Changing h22 PS, Alt, Crank Belts
Old Mar 30, 2008 | 09:43 AM
dre2day's Avatar
Default Changing h22 PS, Alt, Crank Belts
I was reading the service manual and it said you unbolt 2 bolts on the ps but I didnt see anything about the other belt. I'm sooo used to auto tensioners, that its sad I have to ask....
Old Mar 30, 2008 | 02:58 PM
dre2day's Avatar
Default Re: Changing h22 PS, Alt, Crank Belts (dre2day)
bumb
Old Mar 30, 2008 | 04:37 PM
K-Litt's Avatar
I found these pages that talk about adjusting/removing PS and Alt. There's an adjusting bolt and a lock nut for each.
17-74 PS
23-113,114 Alt
Hope that helps.
Old Mar 30, 2008 | 04:45 PM
dre2day's Avatar
Default Re: Changing h22 PS, Alt, Crank Belts (K-Litt)
cool. service manual or helms?
Old Mar 30, 2008 | 04:47 PM
K-Litt's Avatar
sry, service manual
Old Mar 30, 2008 | 04:48 PM
dre2day's Avatar
awsome thanks! looks like i need a ruler or tensionar gauge
Old Mar 30, 2008 | 04:51 PM
98vtec's Avatar
moderator emeritus
loosen the alternator bolt then loosen the mishaped nut which keeps the alternator from moving, then loosen the adjusting nut (right). push the alternator down and remove the belt.
Seatown
17
Apr 5, 2007 02:33 PM
graphic
Nov 1, 2004 10:23 PM
BrandonClaps
Nov 10, 2003 10:08 PM
slowexcoupe
May 20, 2003 06:58 AM
Yuleluder
May 10, 2003 08:13 AM
