idle issue
I have a completely stock 2002 rsx type s w/ 116k and with all scheduled maitenence.
the car has been throwing a cel randomly for the past month or so but i would just clear it because the car runs fine, assuming it was something minor
this morning i started my car it would not cold idle, meaning when it was cold it would idle at 500 rpm's, normally it would idle at 2,000-1,500 rpm's when cold.
i am confused as to what this could be because i did absolutly nothing to it between last night, when it was running fine and this morning when it was not running fine.
at first thought i would think it was the idle air control valve or 'rotary air control valve' but once the car warmed up it went back to a decent idle (around 800-700 rpm)
has anybody else ever dealt with a problem such as this and has any input because i am slightly stumped considering it was running fine less than 12 hours ago then randomly doesnt work perfect anymore.
Thanks in advance for any help.
i checked the code and it said that the cat isnt working as well as it should so the code has nothing to do with the problem.
so like i said, the car will start up and be cold but will idle at 500 rpm's and even lower and sometimes so low it will stall out. If i rev the car past 5,000 rpm's it goes back to normal. Any input on this issue?
I had a similar problem. It would get better as I reset my ECU via the fuse, but what made the biggest difference was replacing my air flow sensor, that cured my problem right up.
TearSDMF89dx
Jan 3, 2012 04:31 AM
