Suspension & Brakes Theory, alignment, spring rates....
Ground Control COILOVERS not low in rear
Old Mar 30, 2008 | 12:10 AM
lsvtek's Avatar
Default Ground Control COILOVERS not low in rear
Hi, I bought Ground Control COILOVERS with Tokico Illuminas. My problem is that my rears dont go that low, I still have a gap inbetween the tire and fender... Can anyone help me on this? Thanks in advance
Old Mar 30, 2008 | 10:59 AM
Johnny Mac's Avatar
Default Re: Ground Control COILOVERS not low in rear (lsvtek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtek &raquo;</TD></TR><TR><TD CLASS="quote">Hi, I bought Ground Control COILOVERS with Tokico Illuminas. My problem is that my rears dont go that low, I still have a gap inbetween the tire and fender... Can anyone help me on this? Thanks in advance </TD></TR></TABLE>
Maybe you need shorter springs.
Old Mar 30, 2008 | 03:54 PM
Targa250R's Avatar
be professional
To even begin to analyze your problem, you're going to have to figure out what is limiting the height.
Are the dampers sitting on the bump stops at static ride height? Did you trim the bump stops when you installed them, and if so, how much did you trim off and how much did you leave? Are there any threads left on the sleeves underneath the perches, or do you have the perches set all the way down at the bottom of the sleeves? What spring free lengths and rates are you using?
Old Mar 30, 2008 | 03:58 PM
bmoua's Avatar
Default Re: Ground Control COILOVERS not low in rear (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
Are the dampers sitting on the bump stops at static ride height? Did you trim the bump stops when you installed them, and if so, how much did you trim off and how much did you leave? Are there any threads left on the sleeves underneath the perches, or do you have the perches set all the way down at the bottom of the sleeves? What spring free lengths and rates are you using?</TD></TR></TABLE>
maybe you put the wrong coilover collars in the back...
Old Apr 4, 2008 | 05:05 PM
lsvtek's Avatar
Default Re: Ground Control COILOVERS not low in rear (bmoua)
Hi, my back shocks didnt even have bump stops. And also I checked the sleeves and they are in there right places. Can anyone show me there car with ground control coilovers? Thanks
Old Apr 4, 2008 | 11:03 PM
baaao's Avatar
i thought ground-controls allow integras and civics to be very low; almost to-the-rim low! on my prelude, the front's ride height cannot be adjust to go that low, but the rear is capable of tucking half of the tire.
Old Apr 6, 2008 | 08:32 PM
lsvtek's Avatar
Default Re: Ground Control COILOVERS not low in rear (baaao)
ya idk wtf is going on. I mean it is okay, but id like to go down more. i checked to see if i put everything in the right place, and i did. I just dont know whats going on....
Old Apr 6, 2008 | 10:39 PM
baaao's Avatar
maybe you have your springs reversed? or...if it's really bugging you, i heard for ground-controls you can place threaded sleeve upside down so it'll allow you to go lower.
Old Apr 7, 2008 | 06:57 AM
gabebauman's Avatar
How long are your rear springs? 7in or 8in? What are the numbers on the springs? Please post pix.
Old Apr 8, 2008 | 10:19 AM
jeremyvr6's Avatar
Default Re: Ground Control COILOVERS not low in rear (gabebauman)
are your sleeves menat for tokivo's or are they for a dieffernt strut.
Old Apr 11, 2008 | 09:20 AM
GroundControlTrevor's Avatar
Default Re: Ground Control COILOVERS not low in rear (jeremyvr6)
what is your spring rates? any pictures of your setup?
Old Apr 12, 2008 | 09:43 AM
ilikehonda's Avatar
i can almost set my car on the ground with the gc's
Old Apr 17, 2008 | 02:49 PM
lsvtek's Avatar
Hi again, so the front coils on my car right now are shorter then my rear ones. I believe this is my problem right here then huh I guess I put the coils in the opposite way. So ill have to change them around
Also a picture of my car ith the front coils ALL THE WAY UP and the rears ALL THE WAY down
Old Apr 17, 2008 | 02:57 PM
Targa250R's Avatar
be professional
You definitely have the springs on the wrong ends.
Old Apr 17, 2008 | 03:03 PM
lsvtek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">You definitely have the springs on the wrong ends.</TD></TR></TABLE>
Yep, about to swith them around when it gets cooler lol
Old Apr 17, 2008 | 10:05 PM
CE1's Avatar
CE1
or you can cut the perch off of the struts to let the coilover perch spin all the way down. running the stiffer spring on the back will make it handle better at the track.
Old Apr 17, 2008 | 11:12 PM
BinMop's Avatar
i have gc/koni on my integra and im tucking like half of the tire in the back, but im on like the last tread , i thought i could be this low and have the adjustment thing be mucher higher?? spring rate 300f/250r
Old Apr 17, 2008 | 11:23 PM
TheTealHatch's Avatar
Default Re: Ground Control COILOVERS not low in rear (BinMop)
Cut the cup in half or just flip the cup and you would be able to get lower
Old Apr 17, 2008 | 11:26 PM
BinMop's Avatar
Default Re: Ground Control COILOVERS not low in rear (TheTealHatch)
i have no cup, im riding on gc/koni set up, where the sleeves slide right on to the shock
Old Apr 17, 2008 | 11:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BinMop &raquo;</TD></TR><TR><TD CLASS="quote">i have gc/koni on my integra and im tucking like half of the tire in the back, but im on like the last tread , i thought i could be this low and have the adjustment thing be mucher higher?? spring rate 300f/250r</TD></TR></TABLE>
Get stiffer springs so you wont bottom out as much. You will feel the difference of ride compare to what you have right now.
Old Apr 17, 2008 | 11:57 PM
BinMop's Avatar
wouldnt getting stiffer springs make me bottom out more?
Old Apr 18, 2008 | 12:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BinMop &raquo;</TD></TR><TR><TD CLASS="quote">wouldnt getting stiffer springs make me bottom out more?</TD></TR></TABLE>
Nope. Its going to make you have a stiffer ride
Old Apr 18, 2008 | 06:44 AM
gabebauman's Avatar
Which groove is your circlip set at? There are three grooves on the rear shock and two on the fronts with my Koni Yellows.
Old Apr 18, 2008 | 08:16 AM
BinMop's Avatar
i cant tell exactly , ill take a pic later today, hopefully this is the problem, its kinda scarey riding on the last tread
jr000
Mar 16, 2008 07:42 PM
redDAinteg
Jan 24, 2007 07:37 AM
MenaceL.A.671
11
Jan 15, 2007 03:56 PM
TypeR15
Sep 8, 2004 02:39 PM
[HrZn]4life
Jan 14, 2003 09:01 AM
