#739 Dyno Numberss!!!!!
Old Mar 29, 2008 | 09:07 PM
WheaMyRyceGo's Avatar
Default #739 Dyno Numberss!!!!!
i am not sure if i should be upset or happy. it seems like it pulls really hard but it didnt put down the numbers i expected.
SAE 174.87whp and 123.76wtq
i will try to get the graph up as soon as i find a camera
I put down 158whp and 118wtq stock, but this dyno was done about a year ago
BPI stack w/ K&N filter on a 3" SRI
Hytech Antireversion Header
T1R 2.5" Exhaust
Do you guys think id be able to squeeze out an extra 6whp? Crome is the program ill be using
Old Mar 29, 2008 | 10:01 PM
SpdFrk's Avatar
Default Re: #739 Dyno Numberss!!!!! (WheaMyRyceGo)
Is this with a stock ecu?
Old Mar 30, 2008 | 08:47 AM
Default Re: #739 Dyno Numberss!!!!! (SpdFrk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpdFrk &raquo;</TD></TR><TR><TD CLASS="quote">Is this with a stock ecu?
yep but i just bought a chipped/vtec p06 and im going to get it tuned with crome
Old Mar 30, 2008 | 09:48 AM
Fat Chick Magnet's Avatar
buy cam gears while you're at it and tune it on cam gears also you will make more power.
Old Mar 30, 2008 | 09:50 AM
Default Re: (Fat Chick Magnet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Chick Magnet &raquo;</TD></TR><TR><TD CLASS="quote">buy cam gears while you're at it and tune it on cam gears also you will make more power. </TD></TR></TABLE>
what cam gears should i purchase? i was thinking about having a hondata IMG and MAYBE a mugen headgasket before the tune also
Old Mar 30, 2008 | 09:54 AM
white rocket's Avatar
Default Re: (WheaMyRyceGo)
I'd opt for the Skunk 2 Pro Series cam gears since they have 6 bolts. You should be able to get to 180 with tuning and the gears.
Old Mar 30, 2008 | 02:50 PM
Default Re: (white rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket &raquo;</TD></TR><TR><TD CLASS="quote">I'd opt for the Skunk 2 Pro Series cam gears since they have 6 bolts. You should be able to get to 180 with tuning and the gears.</TD></TR></TABLE>
skunk2 pro series cam gears it is! thank you! the shop said they could probably already get 180 with just a tune so hopefully cam gears will get me something extra
Old Mar 30, 2008 | 05:53 PM
yeah skunk2 pro series cam gears.. just how he said above.. the 6 bolt one is good.
Old Mar 30, 2008 | 06:15 PM
SkimN's Avatar
Bisimoto no slip cam gears FTW
Old Mar 31, 2008 | 04:25 PM
OH_1fstgsr's Avatar
WheaMyRyceGo
Really good numbers for the stock ECU.
I think with a good tune 6whp is very possible. Years ago with a VAFC ITR's with similar set-ups where around 190whp.
What are you running between the header and the exhaust? Test pipe or a cat?
Old Mar 31, 2008 | 04:45 PM
Default Re: #739 Dyno Numberss!!!!! (OH_1fstgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OH_1fstgsr &raquo;</TD></TR><TR><TD CLASS="quote">WheaMyRyceGo
What are you running between the header and the exhaust? Test pipe or a cat?</TD></TR></TABLE>
i guess the numbers are good, but they werent what i expected. im also running a custom test pipe its approx 5-6inches
Old Mar 31, 2008 | 07:34 PM
importknight's Avatar
it seems everyones itr is different, ive seen bpi, hytech and exhaust make 189whp on here, weirddd
Old Apr 1, 2008 | 07:27 AM
jomama's Avatar
what kind of dyno was used?
Old Apr 1, 2008 | 09:22 PM
Default Re: (jomama)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jomama &raquo;</TD></TR><TR><TD CLASS="quote">what kind of dyno was used?</TD></TR></TABLE>
DynoJet, does this typically read lower than other dynos?
Old Apr 1, 2008 | 10:04 PM
mtber's Avatar
+2
midnitesol
May 16, 2007 08:24 PM
FrostyDC4
Dec 1, 2004 09:03 AM
honda06si
13
Oct 9, 2004 03:31 PM
BLK99VTECR
Sep 14, 2003 06:45 AM
Tuney
Apr 23, 2003 12:59 PM
