please help....sohc zc swap in my rex??
so im thinking i about getting this sohc zc a guy wants to trade me... but i want to know what im getting my self into. i have a 89 crx si. what do i need other than the motor??? will it bolt right in? what's the perferred ecu?
thanks to anyone that helps!!!!
Search around. You'll find your answers. Any motor swap is going to be more complicated then just "bolting it in" and going. Expect to run into things.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by draperj09 »</TD></TR><TR><TD CLASS="quote">Search around. You'll find your answers. Any motor swap is going to be more complicated then just "bolting it in" and going. Expect to run into things.</TD></TR></TABLE>
retard
BOLTS RIGHT IN , DIRECT REPLACMENT
86-89 integra ecu is slightly better for the ZC but yours will work fine. The integra ecu has a better fuel map and higher red line.
retard
how exactly can i use the same ecu?? when the zc is vtec and my stock engine isnt vtec? dont i need an ecu that can read the vtec??
You would be better off telling people what [freak]ing engine you have other than what you have posted so far.
You will need to do a OBDO to OBD1 swap with the ecu and wiring now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 »</TD></TR><TR><TD CLASS="quote">You would be better off telling people what [freak]ing engine you have other than what you have posted so far.
You will need to do a OBDO to OBD1 swap with the ecu and wiring now.</TD></TR></TABLE>
Absolutely, there are many ZC variants. If this is a SOHC VTEC ZC, you will need to convert to OBD1 and get an OBD1 ECU or get your PM6 chipped. All of your other stock components will work.
Eron.</TD></TR></TABLE>
Bryan
OP, you will also need to wire in VTEC and the knock sensor. I also think Rywire may manufacture a pre-made harness that will take care of this for you though.
Eron.</TD></TR></TABLE>Bryan
