Trouble with Summit Carbide Bur for Porting Aluminum Honda Heads
Old Mar 29, 2008 | 06:09 PM
b20vtech's Avatar
Default Trouble with Summit Carbide Bur for Porting Aluminum Honda Heads
Ok, i don't know if it's me or the carbide bur, but when i tryed it on a spare head, it makes very deep cuts and and it's hard to get a even cut pattern on the walls. Anyone have this problems with Aluminum carbide burs? I try to even out the walls by polishing it up with 60grit cartridge rolls but it won't cut it! is there any other carbide burs thats easier to work with on these aluminum heads?
- reguards Kevin
Old Mar 29, 2008 | 06:26 PM
dave@passenger's Avatar
Default Re: Trouble with Summit Carbide Bur for Porting Aluminum Honda Heads (b20vtech)
Kevin, I assume you are using single (fast) cut carbides? If so that is why you are getting a rough surface finish. We only use single cut when we need to remove a LOT of material, other wise we use double cut burrs more commonly used on steel to get a smoother cut surface, to avoid clogging the double cut burrs quickly use some cutting fluid, or light penetrating oil like wd-40.
Old Mar 29, 2008 | 06:36 PM
b20vtech's Avatar
Default Re: Trouble with Summit Carbide Bur for Porting Aluminum Honda Heads (dave@passenger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dave@passenger &raquo;</TD></TR><TR><TD CLASS="quote">Kevin, I assume you are using single (fast) cut carbides? If so that is why you are getting a rough surface finish. We only use single cut when we need to remove a LOT of material, other wise we use double cut burrs more commonly used on steel to get a smoother cut surface, to avoid clogging the double cut burrs quickly use some cutting fluid, or light penetrating oil like wd-40.</TD></TR></TABLE>
so that's the secret!! where can i find decent ones, beside summit ??
Old Mar 29, 2008 | 06:47 PM
There are two basic types of carbide, single cut (usually for Al and plastics), and double cut (usually for steels). Double cut are far more common and available pretty much anywhere you can buy decent hand tools. That said long shank carbides needed for porting we buy online, from Cylinder Head Abrasives.
Old Mar 30, 2008 | 06:49 AM
Metal Head's Avatar
nothing wrong with summits carbide burr, your just using the wrong bit for the job/ level of experience.
HT Chaplain
Welding / Fabrication
31
Aug 7, 2007 06:41 AM
@irborne
14
Jan 29, 2006 09:53 PM
Want2race
Feb 16, 2005 04:12 AM
rice a roni
Sep 7, 2004 09:57 AM
DMF
May 10, 2004 08:27 AM
