Smog w/ ctr parts?
Can i still pass smog w/ ctr piston and camshaft on a gsr block w/ b16 head? Or itr piston and itr camshaft w/ gsr head? Which combination of this is better and has more power? I know i have to buy a high performance radiator cause too much compression.
yes cause without a high performance radiotor and too much compression, the car will run hot. So you need a performance radiator to lower the temperature.
