temp gage problem with b16A! HELP
Old Mar 29, 2008 | 01:53 PM
JUN.'s Avatar
Default temp gage problem with b16A! HELP
Hi guys, I just swaped a b16A and it works fine but my temperature gage is acting weird. It goes up to normal temperature (less than half) and it stays that way for a while and then it goes to H instantly......
It did it twice and my fan didnt even turned on so my guess is that the car is not overheating and there is something wrong with the gage or gage sensor.
Have anyone had this problem before?
Old Mar 29, 2008 | 01:55 PM
dr_latino999's Avatar
Default Re: temp gage problem with b16A! HELP (JUN.)
Does it stay at H or do you freak out and turn it off negating this question?
Old Mar 29, 2008 | 03:29 PM
JUN.'s Avatar
Default Re: temp gage problem with b16A! HELP (dr_latino999)
it stays on normal for a while and then it goes to H instantly. Then I freak out and turn it off.....
Maybe there was alot of air in the system?
Old Mar 29, 2008 | 06:06 PM
Maxcapacity's Avatar
I'm 99% sure you have a bad connection with the temp. sending unit. I have had the same problem before and this was the problem. the little boot around the wire at the connector of the sending unit will push the wire off slightly causing this.
I just trimmed the boot shorter to fix this and gave the connectors a good cleaning to solve this odd problem.
Old Mar 29, 2008 | 06:37 PM
sirtef9's Avatar
Default Re: temp gage problem with b16A! HELP (Maxcapacity)
Check your thermostat ground.
Old Mar 29, 2008 | 06:52 PM
JUN.'s Avatar
Default Re: temp gage problem with b16A! HELP (sirtef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirtef9 &raquo;</TD></TR><TR><TD CLASS="quote">Check your thermostat ground.</TD></TR></TABLE>
oops I dont have that
95TeggyB20Vtec
Aug 8, 2011 09:22 PM
KayTran
Dec 16, 2008 12:06 PM
Pilot05
Sep 15, 2006 03:44 PM
JunkyardDog
Nov 28, 2005 11:02 AM
DEVIN22CBR
Apr 9, 2003 12:27 PM
