What is your timing at, and what octane do you use?
the overall point is to see what everybody else is running, havent seen a thread like that before.
And 2 is, when I put the timing on my d16y8 to 16, and ran 87-89, now my engine seems to smoke and loose coolant.
but how do you know with a higher octane, that your burning all of the fuel, and not dumping a crap load down past the rings? This is why I wanted to see what everybody was running. For instance if your running 16*, (+2 advanced- stock is 12*) if you would be dumping fuel down the walls into the oil with 91 octane......or even 14* with 91. I have no way to check for knock, and the y8 would retard the timing anyways 3* if it detects it.
you'll get cylinder wash from being rich, not from advancing your timing, you'll get detonation from advanced timing, or pinging.if base timing is @ 12 degress advanced, keep it at that. unless your running race mix.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxsir2 »</TD></TR><TR><TD CLASS="quote">you'll get cylinder wash from being rich, not from advancing your timing, you'll get detonation from advanced timing, or pinging.if base timing is @ 12 degress advanced, keep it at that. unless your running race mix.</TD></TR></TABLE>
sorry a bit confused, im running 2* advanced past stock. OEM is 12* +/- 2*, so im at 16* base.
if im at 16*, what octane do you recommend? i know its a
question, but I have NO way to tell if im pinging, or detonating because of the knock sensor.
Im advanced because it cured my 2-3k flat spot hesitation.
question, but I have NO way to tell if im pinging, or detonating because of the knock sensor.Im advanced because it cured my 2-3k flat spot hesitation.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigsyke »</TD></TR><TR><TD CLASS="quote">Im advanced because it cured my 2-3k flat spot hesitation.</TD></TR></TABLE>
In this case, advancing the timing is a band-aid fix for something else that's wrong. Double check your cam timing.
as if I jumped a tooth? ill check that, i dont have an adjustible gear.
but for ignition setting then, would it be best to have it at 14*btdc? (furthest mark on the crank pully) and run 89?
Azn Kenny
Jan 31, 2006 06:11 PM
B2FiNiTY
11
May 3, 2004 10:21 PM
BlackCRX
21
Oct 16, 2002 01:42 PM
