fs/ft; 95 civic hatch. 12.95 @ 104 on street tires ky
129k on chassis. 25k on motor. Just went to track today and it 12.95 @ 104 So price is 7500 obo
Only problems are trans has 2nd gear grind at normal driving not when you get on it or if you shift low and typical 3rd gear grind and is now popping out of 4th sometimes. ii have taken that in consideration which is why i have is price at 6500. id want alot more if it wasnt for that but i have been driving it around and going to the track fora year now with it like that
Ill post pics later kind of in a rush but here is the link to my car domain.
http://www.cardomain.com/ride/2589993
Engine
Custom 3" cold air with velocity stack
Custom exhuast.
B18c1 block with CTR pistons (12.5:1 compression combo with head)
B18c1 Head
Skunk2 intake manifold
ITR throttle body
Arp Head,Main studs and rod bolts
Custom valve cover
ITR cams / valve springs and retainers
Greddy timing belt
Custom Ground Wire Kit
Chipped P30
CSF 1 1/4 aluminum radiator
CTR N1 Crank pulley
Megan racing 4-1 2.5" collector header
NGK Iridium plugs
NGK plug wires
Avid racing torque mounts
Custom 3'' mid pipe with dump tube for the track
Custom extension with velocity stack for the track
Transmission
ACT HDSS clutch
Fidanza 7.5lb flywheel
B&M short throw shifter
Prothane Shifter bushings
B&M Short Shifter
JDM B16 Transmission
Suspension/Chassis
ETD Full Race Traction bars
OMNI Power Full coilovers
INTEGRA REAR SWAY BAR
Integra Type r strut tower bar
Megan Racing LCAs
Rear Camber Kit
Skunk front upper camber kit
Brakes
Axis Ultimate front pads
Axis Ultimate rear pads
INTEGRA REAR DISC SWAP
painted calipers
Rotora front slots
Rotora rear slots
Interior
Del sol Seats
SI GUAGE CLUSTER
ITR shift ****
Broadway mirror
Exterior
OEM style Carbon fiber hood
96-00 civic side skirts
JDM thin side moldings
Rear Wiper Delete
SIR FRONT LIP
VIS Spoon style C/F DUCK BILL SPOILER
VISION AMBER CORNERS
Jdm sidemarkers
Black housing headlights
Spoon Style mirrors
Buddy Club Blue lug nuts
Wheels and tires
15" kosei K1 racing
General UHP Exclaim Tires
Modified by 13sechatch at 8:19 AM 4/2/2008
Engine
Custom exhuast.
B18c1 Head
ITR throttle body
Custom valve cover
Greddy timing belt
Chipped P30
CTR N1 Crank pulley
NGK Iridium plugs
NGK plug wires
Transmission
ACT HDSS clutch
B&M Short Shifter
Suspension/Chassis
Megan Racing LCAs
Rear Camber Kit
Brakes
painted calipers
Rotora front slots
Rotora rear slots
Interior
Del sol Seats
SI GUAGE CLUSTER
ITR shift ****
Broadway mirror
Exterior
Rear Wiper Delete
SIR FRONT LIP
Jdm sidemarkers
Spoon Style mirrors
Wheels and tires
15" kosei K1 racing
13sechatch
Apr 7, 2008 04:35 PM
13sechatch
Mar 26, 2008 02:56 PM
13sechatch
Southeast (Sales)
Mar 25, 2008 10:10 AM
13sechatch
Aug 27, 2007 03:47 PM
