99 si cluster speedo and temp issue
Old Mar 29, 2008 | 05:51 AM
o0ohaviko0o's Avatar
Default 99 si cluster speedo and temp issue
I got an SI gauge cluster on my 96 ek gsr hatch. My RPMs work and my gas gauge works. But my Speedo and my temp gauge don't move. Is there a way to check if those are functioning on the cluster? Or could it be something else other than the cluster?
Old Mar 29, 2008 | 09:53 AM
Former User's Avatar
Default Re: 99 si cluster speedo and temp issue (o0ohaviko0o)
If the odometer and tripmeter also don't work, then you probably have a bad vehicle speed sensor (VSS). If they work, you speedo is likely bad.
For the temperature gauge problem, troubleshoot the ECT sending unit (one wire) next to the ECT sensor (two wires) under the distributor. If you ground the ECT sending unit connector to the engine, the temperature on the gauge should rise. If this doesn't happen, then the gauge itself is bad. Otherwise, the sending unit is bad.
Old Apr 1, 2008 | 07:04 AM
Default Re: 99 si cluster speedo and temp issue (RonJ@HT)
I just found out the the speedo and temp gauge on my cluster dont work. Is there a way to repair it?
ef9_civic_hatch
Jul 3, 2007 11:06 AM
5thgenallmotor
Dec 7, 2004 07:48 AM
Rhetoric
Sep 14, 2001 06:55 PM
