b18a crx swap
i know this is really old info, but i am new to b series, i have done alot of h22s and wanted help on swapping a b18a1 into my 90 crx si, i have avid mounts, da shift linkage, obdo ecu and am going to get a da rear t bracket,
i wanted to know if i use my si harness do i swap fuel rail and injectors, and would the injectors be big enough/ make car run right with the obdo pr4 ecu.
also i need another engine mount braket for the timing cover side if the engine, the one that bolts to the block, i think i have a 94 and up bracket, cuz the studs are inline and 90-93 are diaganol, can i use a mount bracket from something else.
Excelerate
May 16, 2006 07:13 AM
