Passenger wheel spins...driver side stuck
Today I finished my 1999 Civic Si B16A2 swap into my 1989 Honda CRX Si. I am using a DA automatic passenger side axle (same as manual) and a DC GSR ABS driver side (i know i dont have ABS but according to my research it should work.) on the stock intermediate shaft. When I put the car into gear the car moved but seemed to be struggling (as if the parking brake was on...but it was not). My brother said he heard a crack when it first started moving so we jacked the car up. I put it in gear and took out the clutch but only the passenger wheel spun. The driver side wheel was not spinning, neither was the axle or half shaft. I think my brake is stuck on the driver side but we did not have time to double check it as it was late. What other things do you guys think I should check tomorrow or could possibly be the problem?? Also, does it make sense that only the driver side brake is stuck? we thought it was kind of odd. Thanks in advance.
Well, I know I was supposed to and I checked but am not exactly sure what they look like. I searched here on HT but could not get a good picture of them. Do you think you can post one up??
BubbleBoy86
Jun 29, 2012 11:18 AM
HondaJon
Honda Civic (2006 - 2015)
Oct 6, 2008 11:28 AM
