Does honing change the piston bore size
Old Mar 28, 2008 | 06:31 PM
um3r's Avatar
Default Does honing change the piston bore size
hey guys
I have a 90 Honda accord.on my way back home my camshaft broke, which also messed up my head block. now i m buying a new block from junk yard and getting it resurfaced. But the main thing is that my car use to burn a lot of oil when it was running, so now i m thing of putting new piston rings while i have opened the engine. But i have heard that before putting new piston rings the piston bore should be honed. Is it possible that i can hone the bore by my self, and does it changes the size of the bore. because i was thinking of use the same pistons but with new rings on it.
Old Mar 29, 2008 | 08:13 AM
not-a-stang's Avatar
Default Re: Does honing change the piston bore size (um3r)
No. Honing shouldn't change your bore diameter.
Old Mar 29, 2008 | 10:44 AM
hondadude's Avatar
You should Google search "plateau hone" to learn a little more.
http://www.babcox.com/editorial/ar/eb40250.htm
The idea is that the scuffing creates peaks and valleys in the cylinder wall.
the peaks get worn flat by the piston rings while the valleys retain oil for lubrication.
In your engine you will see the factory hone marks when you open it up.
the probable cause of your engine burning oil was collapsed oil wiper rings.
There is actually a tool, like a old record player needle that is used to check the R.A. [roughness average] and it sends a graphing signal to a recorder.
When Soichiro Honda designed the first Honda engines he made the cylinder walls slightly harder than the piston rings.
This is the reason that pre98 engines can almost always be rebuilt with good success.
But in 98 due to CAFE ratings implemented by the FED, Honda Engineers came up with the "composite" cylinder wall, that wears out. Making those engines too costly to rebuild. Pressing in cylinder liners isn't cheap
I'm sure Soichiro Honda rolled over in his grave when that happened.
Old May 6, 2008 | 11:04 PM
bluetintruben's Avatar
Default Re: Does honing change the piston bore size (hondadude)
That has to be some of the coolest information I've read in a while.
Thanks for that input!
XVNVX
Engine Machining & Assembly
Apr 24, 2017 01:00 PM
Yambor
Apr 29, 2005 10:55 PM
Layziebtnh055
Jul 5, 2004 06:08 AM
SupaFly_Honda
Jan 21, 2003 06:53 AM
BLKCRX
Jul 24, 2002 03:40 AM
