Need help with 98 accord h22 swap
Old Mar 28, 2008 | 06:13 PM
blackdelslo's Avatar
Default Need help with 98 accord h22 swap
What I have is an auto 98 accord that was converted to 5spd. Im using the stock auto engine harness on the h22 which is obd2a and also wanting to run the conversion harness to go from obd2b - obd1.
My question is that the stock accord has 4 ecu plugs A B C and D. What I need to know is that the D plug is all auto stuff right? Because when i use the conversion harness there is no wires that go to it.
I looked at a wiring diagram on phearable for obd2b cars and some of the wires are not the same color that the website says they should be in the same spots.
Is this swap the same deal as the civic/integras or does the 6th gen accords have something slightly differant?
I should just be able to use the stock engine harness, mate it to a conversion harness and then just add any wires i need for the h22 right? No switching pins to differant plugs and stuff right?
Old Mar 28, 2008 | 08:06 PM
whitejm's Avatar
Here's one of the best h22 resources on the web for the 6th gen.
http://www.everything-honda.co...=3843
jccrews90
Mar 14, 2012 03:57 AM
TheRedEM1
Apr 25, 2009 07:56 PM
timbrewolf
Feb 12, 2009 06:43 PM
hondatuningboi96
Jun 7, 2006 03:58 AM
greenli0n25
May 8, 2003 09:55 AM
