possible kpro ecu problem... any1 got one?
Old Mar 28, 2008 | 02:40 PM
thareddb's Avatar
Default possible kpro ecu problem... any1 got one?
hey all yesterday i was driving my k20a2 swapped eg when it suddenly started to studer then died!
i went to start it and nothing! but i noticed i didn't here my loud *** 255 fuel pump priming so i checked my fuel pressure gauge and sure enough 0
i then switched out my fuel pump with a extra one i had laying around and still nothing.
so then i switched out my main relay with a known working one and still nothing!
so now i am thinking its possibly my ecu. i do have a cell but that is because i have no o2 sensor on the car and i have verified this with a obd2 scanner about 2 weeks ago. but now when i try and hook up the ecu to the same obd2 scanner i am not getting any signal
any1 have any suggestions?
or does any1 in nor cal bay area have a rsx or a k swapped civic i can test my ecu in or a ecu that i can try on my car it would really help me figure out what is exactly wrong
Old Mar 28, 2008 | 03:46 PM
mtber's Avatar
Default Re: possible kpro ecu problem... any1 got one? (thareddb)
Plug into the kpro ecu using a laptop to see if you can connect to it. If you are still having problems take the vehicle to a local hondata dealer.
Old Mar 28, 2008 | 04:08 PM
ekb16's Avatar
have u tried checking ur fuses?
Old Mar 28, 2008 | 07:09 PM
thareddb's Avatar
Default Re: (ekb16)
yeah fuses are fine
and yeah when i try hooking the hondata up to the lap top it says its not connected check connection or try a deferent usb port or a deferent computer. i called modacar a local hondata dealer and told them my problem and they said i could bring it to them and they can send it to handata for a diagnostic ($100 plus $18 to send it ther and another $18 to send it back)
right now the only thing i can really think of doing is tryin to find another car to test my ecu on or trying to find another ecu to try in my car if i cant do that i think ill send the ecu back to handata...
any1 have any other info or suggestions i should try b4 i spend the $140
come on HONDA-TECH FTW
Old Mar 29, 2008 | 02:29 PM
thareddb's Avatar
Default Re: (thareddb)
up for the K being down
sux it being my dd
speedsk899
Jun 13, 2014 05:07 AM
averyvm
Engine Management and Tuning
17
Aug 2, 2013 05:40 AM
redline32
Jul 9, 2009 10:32 PM
hybridb18
Apr 9, 2004 04:09 AM
EE9
Jan 2, 2003 06:04 AM
