Clutch master cylinder seal replaceable?
Old Mar 28, 2008 | 11:27 AM
SOHCMAN's Avatar
Default Clutch master cylinder seal replaceable?
http://www.hondaautomotivepart...INDER
My clutch master cylinder weeps a small amount of fluid onto the area behind the clutch pedal. There is a seal (#10) but thats not what's leaking is it? Its a seal inside the master cylinder and its non replaceable correct?
Its only enough I need to top off every few months, but I was considering replacing it anyway while I do other clutch work...
sohc
Old Mar 28, 2008 | 05:17 PM
hondadude's Avatar
Default Re: Clutch master cylinder seal replaceable? (SOHCMAN)
Item # 10 is not the problem;
There are aftermarket rebuild kits from the parts stores, but the time and effort of rebuilding the clutch master may not be worth the effort.
Many times there has been moisture settled into the bore and caused corrosion, and that is the real cause of the seal going bad.
Old Mar 28, 2008 | 05:38 PM
Derek128's Avatar
just buy a new one
its easier & not that expensive
crxricer66
Dec 1, 2007 07:58 PM
perseverance
Dec 29, 2006 04:47 AM
97tegGS
Jun 10, 2005 05:13 AM
phantom_sol
Oct 8, 2003 08:14 PM
