Help with built B16.
Old Mar 28, 2008 | 08:06 AM
B16A CRX's Avatar
Default Help with built B16.
I have a completely built high compression B16. pistons, rods, cams, blah blah blah. My problem is that the car wont idle for more than five minutes without turning off. After it turns off itll turn right back on but it eventually turns off again. IT has a very rough idle that i think its due to the cams. I tried to check what codes the ecu is throwing but when i try to chech it the check engine light flashes 7 times 7 quick flashes. What does that mean. Could one of my problems be vacuum hoses. I have the pcv, brake booster, and fuel vacuum lines connected.
Old Mar 28, 2008 | 08:15 AM
SIred91's Avatar
Rainman
Default Re: Help with built B16. (B16A CRX)
So check what a code 7 is.
Old Mar 28, 2008 | 08:20 AM
zccr-xsi's Avatar
code 7 is tps sensor.have u set the volts on it yet?
Old Mar 28, 2008 | 09:11 AM
B16A CRX's Avatar
Default Re: (zccr-xsi)
wut does it mean to set the volts
Old Mar 28, 2008 | 09:16 AM
B16A CRX's Avatar
Default Re: (B16A CRX)
ok i read up on adjusting the sensor. but i don not understand how to back probe or what it means to do that.
z06eateR
Jul 1, 2010 07:55 PM
slowcrxsi
Mar 28, 2006 12:37 PM
B1692LS
Feb 19, 2005 01:56 PM
Josh717
Dec 15, 2002 11:09 AM
NikoZai
Aug 30, 2002 12:34 AM
