DIY cai dyno?
Old Jul 9, 2002 | 04:32 PM
b18bfreak's Avatar
Default DIY cai dyno?
Wondering if anyone has done a dyno with one
or a comparison to the aem or icebox.
Old Jul 9, 2002 | 05:36 PM
Mt3c's Avatar
Default Re: DIY cai dyno? (b18bfreak)
the search button is your friend...
https://honda-tech.com/zerothread?id=189419
Old Jul 9, 2002 | 06:24 PM
Asahi's Avatar
Default Re: DIY cai dyno? (Mt3c)
note that was on a Type-R and not a GSR that pulls warm air and has a more restrictive airbox. you might see an actual gain on a GSR.
Old Jul 9, 2002 | 06:55 PM
b18bfreak's Avatar
Default Re: DIY cai dyno? (Asahi)
I should have been more specific.
I was talking about the bsq icebox.
I don't think I found any dynos on that one.
Old Jul 9, 2002 | 06:58 PM
Asahi's Avatar
Did you even read the post Mt3c posted above? I used SPECIFICALLY the BSQ Icetake purchased from Bret himself.
Old Jul 9, 2002 | 07:00 PM
Asahi's Avatar
here. The smartass dyno operator thougtht he would be cute and call it the ghetto take when I told him it was called the icetake.
Old Jul 9, 2002 | 07:08 PM
b18bfreak's Avatar
Thanks for that info..
I have an AEM and some people
were claiming that the bsq was as
good as the comptech icebox.
It basically the same design so I figured
it would be. Guess I'll stick with my AEM.
I do respect the bsq however.
Old Jul 10, 2002 | 06:39 AM
BSQ's Avatar
BSQ
As Asahi mentioned, he purchased my Icetake CAI (aka. DIY "Icebox" - http://www.geocities.com/bretq/DIY_Icebox_CAI.html ) and did some dyno (AEM vs. Iceman vs. Icetake) runs with his '98 Type-R. After reviewing the dyno runs, I emailed Asahi the following message.
I was fairly pleased to see that the my Icetake did so
well against the AEM and the Iceman. I would like to
have seen a little bit higher HP in the upper RPM
range (7,500+ RPM). But over all I think it performed
pretty good...especially when you factor in the cost.
I have been giving some serious thought into the
reason why the Icetake CAI feel short (when compared
to the AEM and Iceman) on the dyno. I have two
theories.
The first theory is turbulence. I inspected the
Icetake tubing extensively after your dyno runs and I
did find a small area in the tubing which has a small
ridge. I found the ridge in the connection between
the 7" PVC tubing and the PVC 90 degree elbow. The
ridge only extends ~1/16" and for about 45 degrees of
the tubing. Now this may not sound like a big deal,
but as the velocity of the air is speeding up in the
tubing this ridge could cause enough turbulence inside
of the tubing which could disturb air flow especially
in the upper RPM range (7,500+ rpm). This can be
easily fixed by reversing the placement of the 7"
white tubing and the black air horn (speaker port).
The tubing fits snuggly together (no glue or adhesive
was used on the joints) so the tubing can be easily
reversed. This simple modification will eliminate the
ridge inside the tubing and eliminate any turbulance
inside the tubing which should show an improvement on
the dyno. It may not gain 6 HP (to make it equal with
the AEM), but it may show an improvement of 2-4 HP.
The second theory is tubing size as you had mentioned.
There is a possibility that the tubing size (3" in
diameter) is restricting air flow in the upper RPM
range. It would be nice to try a 3.5" tubing and air
horn, but I'm not aware of either in 3.5". But on the
flip side the AEM is only 3" in diameter for the
Type-R, so I'm not sure if increasing diameter is the
solution.
One last thought. A lot of people have commented that
the Comptech Icebox does not have the peak HP like the
AEM, so maybe by design the AEM will always have a
higher peak HP.
Since the time of emailing the above comments to Asahi, I have reviewed Asahi's dyno plot and Austin's (H-T Type-R board member) dyno plot (see below) which compares the actual Comptech Icebox vs. AEM vs. Injen and I have come up with the following conclusion. I noticed that in Austin's dyno plot, the Comptech Icebox also started to fall off (when compared to the AEM and Injen) around ~7500 rpm also. So, as mentioned the AEM may always have a slighly higher peak HP number. This could be caused my the design difference between the AEM and the Icebox/Icetake.
Larger image (cut and paste link): http://www.imagestation.com/picture/...1.jpg.orig.jpg
BTW, I am hoping to do some dyno runs comparing my Icetake CAI to the stock intake (and possible other intakes [ie. AEM, Iceman, Icebox]) on my '94 GS-R. When I do so, I will be sure to post the results.
[Modified by BSQ, 11:43 AM 7/10/2002]
Old Jul 10, 2002 | 06:42 AM
Asahi's Avatar
Default Re: DIY cai dyno? (BSQ)
Looking forward to seeing the comparison on a GSR Bret. I suspect you will see more of a gain on a GSR than on a Type-R due to stock airbox design.
I had some other thoughts. Position of the piping in the airbox (Too far in or not in enough) could play a part as well. I think turulance is the biggest problem.
Also on a GSR be sure if you keep the stock snorkle tube to remove the small resonator on the side and plug up the hole.
Old Jul 10, 2002 | 07:28 AM
maggsgsr's Avatar
I've seen the dyno at comptech,but I would much rather see a fellow HT members dyno of an Ice box,Aem,vs Injen.Comptech claims a pretty hefty gain in WHP.
Old Jul 10, 2002 | 07:58 AM
GSRwBOOST's Avatar
Default Re: DIY cai dyno? (maggsgsr)
wow 2-4hp... wheeeewwwwwww hooooooo now thats some power.....
wow.... which means the average intake falls into the 50$ for 1whp catagory... not a bad trade off...
sorry i just hate this nickle and dime bullshit when it comes to "going n/a"... or doing basic mods..
Old Jul 10, 2002 | 08:08 AM
Asahi's Avatar
Default Re: DIY cai dyno? (GSRwBOOST)
What does a turbo break down in HP per dollar? Figure if you get a drag gen 3 kit for $3000 (They are slightly less now) and bolt it on. Figure safe boost at 6-7 psi what hp will you be making? 80-90 whp more? Just over $30 for 1 whp. Now the trade off. Who has $3000 sitting around? Some but not all.
What is the HP/dollar figure when the engine blows up? $65/ 1hp.
This is assuming not building the bottom end but if that was done properly you get back to the $50/hp number for FI
edit: spell check
[Modified by Asahi, 11:10 AM 7/10/2002]
Old Jul 10, 2002 | 08:24 AM
maggsgsr's Avatar
edit: spell check
Old Jul 10, 2002 | 08:27 AM
Asahi's Avatar
BTW, that statement above in no reflects my opinion of FI. I think right under my ITR my choise would be a Turbo'd GSR or a SC'd B18C1 in a Civic Coupe.
FI is fun just pricey
Old Jul 10, 2002 | 08:31 AM
maggsgsr's Avatar
Yea but why go into a post on intakes and start bitchin that its nickle and dime stuff?
Old Jul 10, 2002 | 08:53 AM
GSRwBOOST's Avatar
Take 3000 dollars...
one guy does all "N/A" and one guy goes "turbo"
who do YOU think will be makieng more power?
Old Jul 10, 2002 | 08:56 AM
Asahi's Avatar
Very true. FI is much more fun it you can afford it. I love the kick in the pants of FI
For the poor broke kid who doesn't have $3000, nickles and dimes are a viable way to go a little bit faster.
GSRwBOOST's Avatar
I'm sick of seeing people spend money on parst that give minimal gains.. these advertisers rant about 4hp here and 5hp there... and honestly.. most of the guys I know are either in college and have jobs that dont pay much at the moment. Seeing someone dump 200 dollars in an intake only to get 5whp is depressing since i know they could be spending it elsewhere...
i guess i'm concerned AND a bitchy person today.. sorry..
Old Jul 10, 2002 | 10:50 AM
b18bfreak's Avatar
Great idea bret.
Maybe someone should put together
a "great intake test" just like the
"Great header test"
Maybe APE will be willing to do it some day.
BSQ intake still gets my up.
Old Jul 10, 2002 | 11:09 AM
CKDC2's Avatar
Hehe, but wait, someone forgot the $1500.00 dollars worth of electronics one needs to run a turbo safely. For an all out HP war sure a turbo is the choice however I have seen many turbo cars fall prey to n/a street cars, by the time that turbo spools the other guy is at the next stop light. I think $5000.00 is a more realistic number for a fast, safe, reliable turbo car.
edit: spell check
[Modified by CKDC2, 8:10 PM 7/10/2002]
[Modified by CKDC2, 8:11 PM 7/10/2002]
Old Jul 10, 2002 | 11:22 AM
maggsgsr's Avatar
Default Re: DIY cai dyno? (CKDC2)
edit: spell check
Old Jul 10, 2002 | 12:43 PM
B-Series Sol's Avatar
I had an AEM CAI on my DOHC VTEC del sol... and i decided to order a piece of mandrel bent U pipe from JcWhitney.com... then i followed JDMfan.com's instructions on how to make a CAI... it turned out being a bit harder than I thought it would... but it was cool because my AEM was 2.25" and the one is 3" tubing. The only drawback was the fact that I went from the 2.25" K&N Filter to a 3" Weapon R filter that I had laying around...
All together I notice huge improvements w/ the 3" Custom Intake.. but I wish I had a better filter... some say Weapon R's aren't actually that bad... but they are so ricy
Old Jul 10, 2002 | 01:46 PM
Asahi's Avatar
Default Re: DIY cai dyno? (B-Series Sol)
I would be surprised if the custom manderl bent pipe is making much more power. Seems AEM's shape seems to be well thought through and more so than that compared to a mandrel bent intake is material. Would be interesting to see a dyno comparison. Is your sol a B16 or B18 swap? I would think a b16A would utilize the 3" intake as much as some B18C apps.
Any plans to dyno compare the 2?
Old Jul 10, 2002 | 11:01 PM
no, no plans.. in fact im selling my car and going turbo... the only reason i made the "custom one" is because it was 27 bucks in parts... and it was fun... Plus i sold my AEM CAI and got some money back before I sell it.
Also, dont give AEM too much credit... if u sand down the paint, u will see the welds too... it is mandrel bent aluminum pipe...
I chose to use Mandrel bent steel... which one is better u ask? Steel in this case, because it resists heat. So, my "custom" intake costs about 150 bucks less... and has WIDER tubing that is MORE heat resistant. Maybe I didnt get much gain, but i certainly didnt lose anything, except for a couple metal splinters
Old Jul 10, 2002 | 11:22 PM
Calavera's Avatar
Noob question: Does using different air filters (comptech, K&N, OEM..etc) affect the dyno result in any way? Just curious.
And how the heck did you switch the black air horn and the 7" white piping? I can't pull it off. Okay, may be I need to work out.
Hey BSQ, the black air horn and 7" white piping aren't glued on to the PVC 90 degree bent elbow, right?
