(disk conv) what year rear disk do i need for a 91 4dr dx
oke im going to be off work tomorow so i want to go to a scrap yeard and get a set of rear disks and arms to convert my 4dr 91 dx to rear disk i was wondering what year or integra is best and easyst to use there are 91 93 and 94 and up integras are all rear arms the same whitch one whould u recoment me to use and eney other parts i will be needing
The correct parts to use would be any 90-93 integra rear disc or crx rear disc. You need the complete trailing arm assembly including the toe adjustment linkages brake lines from calipers to chassis (rubber ones) and the e-brake cables.
I'm not 100% sure so correct me if I'm wrong, but I believe you can use rear disc from any 90-01 integra or 88-00 civic with rear disc. just make sure you use your lower control arms etc. so basically just the trailing arms, brake lines and e-brake cables off a 92+ civic or 94+ Integra.
I've seen EK rear drums on a EF hatch and they worked just fine which is why I think you can use disc from anything civic or teg.
But for sure 90-93 teg or 88-91 civic/crx si will work perfect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirRevvs »</TD></TR><TR><TD CLASS="quote">The correct parts to use would be any 90-93 integra rear disc or crx rear disc. You need the complete trailing arm assembly including the toe adjustment linkages brake lines from calipers to chassis (rubber ones) and the e-brake cables.
But for sure 90-93 teg or 88-91 civic/crx si will work perfect.</TD></TR></TABLE>
agree
agree
Sleeper Sii
Sep 15, 2002 03:44 PM
