air conditioning for 1992 dx civic sedan
Old Mar 27, 2008 | 09:39 PM
eg9-626's Avatar
Default air conditioning for 1992 dx civic sedan
So my ac worked this past summer(2007) for the most part, then after that...come november or so, my ac hasnt been working since then. It's getting hotter and hotter out here in cali. Any guesses on what might be going on?
Old Mar 27, 2008 | 09:43 PM
Former User's Avatar
Default Re: air conditioning for 1992 dx civic sedan (eg9-626)
Do you hear the compressor clutch engage when you press the A/C button?
Does the condenser fan turn on when the A/C button is on?
Finally, you might have a refrigerant leak. Use an appropriate set of automotive refrigerant gauges to test whether the refrigerant level may be low.
Old Mar 27, 2008 | 10:00 PM
eg9-626's Avatar
Default Re: air conditioning for 1992 dx civic sedan (RonJ@HT)
yes
yes
and MAYBE i have a leak....the thing is, i remember when i would make a hard left/right turn, water would leak out of nowhere from under the front passengers side...so my excuse to my passengers is that my car likes them...so it lubricated on them. Think this is a major sign of leakage?
Old Mar 27, 2008 | 10:02 PM
The water is normal drainage of condensation (not refrigerant) from the A/C unit; however, the fact that the water is draining into rather than outside of the car is abnormal. Check for a clogged A/C drainage tube.
Old Mar 27, 2008 | 10:39 PM
eg9-626's Avatar
thanks, hopefully i have the time to check the car after work tomorrow...
so2yo1
Mar 7, 2017 04:09 PM
metalmole
Honda Civic (2001 - 2005)
Jun 18, 2014 10:30 PM
jess_95red
13
Jul 31, 2013 09:41 AM
Offspring EK
12
Jun 24, 2009 05:03 PM
gtowni3
Oct 5, 2004 06:19 PM
