Jackson Racing Supercharger for sale!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!
Put PSI Pulley do you have on there...? Does it come complete with all hardware, bolts, etc...?
Comes complete with everything.... ready to smash on type R's
I had the stock ls and it was pretty weak like 4 pounds then i switched it to the B20 crank pulley and it riped 12psi all day.... let me know.... i can work on the price, if your interested let me know.... hit me up!
The lowest setting I got was 3 1/2 psi... fluctuating kinda like boostcreep and it was bunk... it felt kinda like an ls with boltons.... intake mani, and exhaust.... then i switched pulleys and it ran like a champ on 12 psi with a chipped ecu for none turbo and blew the motor, im guessing it was making a lil over 220whp and above 170whp torque all through the powerband, never dynod it but thats on a stock motor using tight gator belts
.... The charger is fine since unlike turbo the only way to damage is to some how shoot a valve backwards through the manifold into the charger but i've never herd of that happening.... the head is fine.... as in the pix the charger was taken appart at JPR for inspection and everything was fine just to be on the safe side....
