wire harness help
it can, but u will need to mod ur distributor and use the sohc injectors unless u do a obd0-obd1 or 2 adapter harness, run the right dizzy and remove the injector resistor box so u can use the newer injectors. what do u plan to do tranny wise? u have several options there as well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ikaika3269 »</TD></TR><TR><TD CLASS="quote">will the 91 si crx wire harness work with the b18b1 motor, and would the stock crx raidator hoses work with that motor or would i have to use the b18 hoses</TD></TR></TABLE>
Yes plug and play besides dizzy. Use the D16A6 injectors in the b18b1 or eliminate the resistor box. If its a 94-95 engine the alternator will work otherwise you'll need a obd0-1 b series alternator. You'll have to re-wire the fan switch to the thermostat housing and convert either your harness or the distributor harness so it'll plug in. The wires are color for color except the si harness has a white wire for the ignition out put signal on the dizzy plugand the LS has a yellow/grn wire.
so what is dizzy. never knew what that was. so what harness would work best. i just want to plug n play. i got the b16 tranny on it all ready. im just trying to find the right wire harness. i just want the car running and leave it alone so my ladie can have it so she can leave her car alone.
LD_EGSICK
Jan 26, 2003 06:42 PM
