zc help ! asap....
ok did a leak down held 160 on all for at lease ten min. when you pull the plug wire off #1 the idle doesnt change. still runs like shi! All plugs are firing and injectors are working what am I missing?????
From: Staring down the barrell of my 12 ga. Texas, USA
on mine the fourth cyl (closest to the distributor) had crank pressure but not pressure when running. i tested the plugs and wires and they were fine with a new dist. i took the head apart and found out the valves, mainly the exhaust were f***ed up. so i just did a zc swap.
