Cluster problem
I just bought another cluster and i though my old cluster lights were bad and the newer one i got does the same thing could it be the main relay or could it be a burned out wire or some thing like that. The only light the cluster displays is the battery light and doesnt come off just stays on. Oh and i just checked the fuses they are all ok
It like there is no power going to the rest of the cluster i am confused i though the other cluster had bad light bulbs but i am puzzled i cant seem to know what else could cause this it worked just find before. some one help
i just started the car and the tech also doesn't work the DIN clock doesnt work. Could it be the main relay i can here it and gas and it starts up but i dont know if that has the cluster going threw it i think it has like 7 diffrent thing going threw it or is there some other fuse relay
did you make sure the new cluster is the exact cluster for your car. if it's not than it will not work correctly. I had the same prob with mine awhile back. does the tach jump when u rev? try a diff cluster...
The cluster is not involved with the main relay at all. It might be that your integrated control unit is out of wack. It's right behind the fuse box under the steering wheel.
eg6REDmilano20
Jan 11, 2010 01:35 PM
