Wraping a turbo in heat wrap????
Old Mar 27, 2008 | 01:22 PM
moores55's Avatar
Default Wraping a turbo in heat wrap????
Dose anyone have any pics of how they wraped there turbo in a heat wrap or a blanket?
Old Mar 27, 2008 | 02:29 PM
rewerbcrx's Avatar
Default Re: Wraping a turbo in heat wrap???? (moores55)
seems like to me you would want your turbo to disipate heat off it... instead of conceiling it. just a thoght.
Old Mar 27, 2008 | 03:18 PM
moores55's Avatar
Default Re: Wraping a turbo in heat wrap???? (rewerbcrx)
No you want to keep it in. The hotter the gases are the faster it will let them move. The heat soak is bad and it can melt things.
Old Mar 27, 2008 | 10:52 PM
Urban_Indian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewerbcrx &raquo;</TD></TR><TR><TD CLASS="quote">seems like to me you would want your turbo to disipate heat off it... instead of conceiling it. just a thoght. </TD></TR></TABLE>
are u the inventor of direct exhaust injection?
research some
Old Mar 28, 2008 | 04:04 AM
blinx9900's Avatar
Default Re: Wraping a turbo in heat wrap???? (KENetics1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KENetics1 &raquo;</TD></TR><TR><TD CLASS="quote">
That is the first time I've ever head that before. I've never heard of heat wrap for a turbo but I've seen turbo blankets. I don't think heat is beneficial to the turbo, it's more to keep the rest of the components around it cooler. i.e. lower underhood temperatures, f*** up the paint on your hood.</TD></TR></TABLE>
zomg on you, seriously are you joking? you heard wrong man.
here is a simple explanation with no big words just for you:
heat=energy, thats what spools the turbo son, the hotter the exhaust gas the faster it flows through the turbo spooling it harder/faster.
if your even thinking for a second your going to argue with me dont bother cause im not gonna waste my time trying to educate you beyond what ive already done. please do some research before doubting other people that are SURE. same goes for you rewerbcrx.
Old Mar 28, 2008 | 06:21 AM
steven_highet's Avatar
Default Re: Wraping a turbo in heat wrap???? (blinx9900)
Heat is the back bone of your engine making power with out it your engine would be a big paper weight. Been able to harness the heat in you engine is a great way to improve power, VE and overall efficiency of your engine. This is why the tuning of A/F ratio has such an impact on power. It all has to do with the increase of heat inside the combustion camber. The leaner the A/F mix the hotter it is going to be. Obviously to lean is bad! But you get what im trying to say. When the spark plug ignites the A/F mixture in the cylinders it is the rapid increase in heat which causes the pressure rise in the cylinder which in turn pushes the piston down. 1/3 of the heat generated is used to create work to rotate you crank, 1/3 of the heat is dissipated into the piston crown, cylinder walls and cylinder head and the last 1/3 is expelled out your engine through the exhaust, That is the beauty of a turbo charger been able to harness the 1/3 of wasted heat and turn it into power. The more heat that is trapped in the correct places the more power you can make.
Ceramic Coatings
For instance, Ceramic Coatings on the piston tops, valves, turbo exhaust
housing, manifold and downpipe, intake manifold, boost piping are great ways to stop heat from dissipating off or into these components. Coatings on your turbo parts will increase turbo spool as there is more heat to generate more work on the exhaust turbine. Coatings on your piston tops and valves will increase the amount of heat expelled out your exhaust system due to the fact that less heat will be absorbed into the metal which in turn again creates more spool on the turbo. It also allows you to run closer piston to bore clearance due to less heat in the piston and less expansion of it. Coating the inside and outside of the intake manifold and using a hondata intake gasket is another great way to improve power. As im sure we all know cooler air is denser which is good for making more power. The reason for this is that when the denser air mixes with the fuel and is ignited the air and fuel molecules are packed closer together which allows for a more stable burn rate and better flame propagation. Then on the other side of the scale if you have a hot intake charge when the fuel is mixed with the air it will evaporate into smaller droplets thus increase the burn rate of the A/F mix when ignited. Fast burn rates can become unstable very quickly! Basically you want the A/F charge to burn slowly and steadily from the center of the combustion chamber to the combustion chamber walls. If not there is an increased chance of detonation and pre-ignition. I have seen tests done on completely stock engines ceramic coating certain components and increasing horsepower by 8%– 12% you take that to your 400HP turbo motor and you are looking at 40 – 50hp plus the added benefit of decreased under hood temps, intake temps, component wear, corrosion resistance, fuel economy.
Heat Wraps
And yes you should wrap your manifold and downpipe and get a turbo heat bag for the exhaust housing. The downside to wrapping these components is the increased
corrosion it will create due to it trapping water. Ceramic coating is the better option but I guess it’s what your wallet can afford. I could go on about this subject for ever. It basically boils down to the basics of controlling heat, making it go where you want it to and keeping it away from what you want it not to get to. There are so many little simple things people, can do to improve the thermodynamics of there engines if they just look at there setup and think about it!! There are plenty books that are dedicated to this topic which can be found under thermodynamics of an internal combustion engine. Well I hope you enjoyed this article. More to come!!
Old Mar 28, 2008 | 11:08 AM
KENetics1's Avatar
i fail so therefor I'll go hide in the corner.
Well I do know that most turbo blankets are made to fit already so you just put it over you exhaust housing and have some type of button to tighten down. I'm guessing it's not too difficult to put on. They are more expensive then the diy kits that have to be cut to fit the turbo. I did find this though on how to measure your turbo to cut the sheet of material:
http://www.heatshieldproducts.com/pdf/turbokit.pdf
IDK just trying to help
Old Mar 28, 2008 | 12:44 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KENetics1 &raquo;</TD></TR><TR><TD CLASS="quote">i fail so therefor I'll go hide in the corner.
there are also metal heatshields that look nice and fancy but thats more to protect your near by wires/hoses, the turbo blankets and ceramic coatings work pretty well, ive used both and with the laser heat gun thingy you can see a major difference.
thegeezerkid
Jun 14, 2008 10:56 PM
RACEPAK
Jan 22, 2008 05:50 PM
greygoose
Dec 30, 2007 05:23 PM
Exvtec king
17
Jul 10, 2007 11:07 AM
Mr HYDE
Oct 3, 2006 04:03 AM
