Weird Sound when making left turns..
Old Mar 27, 2008 | 12:16 PM
gqstatus05's Avatar
Default Weird Sound when making left turns..
96 Honda Acc LX
When I make a left turn it makes a sound like i'm dragging a frying pan. I took a look under the car didn't find anything so I took it to my mechanic where he lifted it up and shook exhaust, blah blah blah and he couldn't find anything. Paranoid I told him to take a ride with me and the freaking car didn't make one damn sound. After I drop off mechanic and get almost home it starts again. The sound is like a piece of metal sheetmetal box with marbles inside dragging on the ground. Only happens when I make a left turn at slow speeds ranging from 10-30 mph. What could it be?
Old Mar 27, 2008 | 12:20 PM
Quad-Damage's Avatar
Default Re: Weird Sound when making left turns.. (gqstatus05)
Check your Axles? To see if they are ripped or leaking? or broken?
Old Mar 27, 2008 | 12:33 PM
gqstatus05's Avatar
Already did, none of them are ripped or torn. As in the rubber boot part. I will take another look at it again to see
Old Mar 28, 2008 | 04:53 PM
gqstatus05's Avatar
Default Re: (gqstatus05)
BUMP
Old Mar 28, 2008 | 05:30 PM
Heinekenf22's Avatar
yea i would check axles. and switch them out
Old Mar 29, 2008 | 01:29 AM
SuShiBoiiii's Avatar
Default Re: (Heinekenf22)
check the brakes something might be loose when you turn left? i know i had a rock stuck inbetween my caliper and rotor man that **** sucked
Old Mar 29, 2008 | 08:07 AM
not-a-stang's Avatar
Default Re: (SuShiBoiiii)
I think one of your brakes is dragging. Check if one of the rotors is darker (purplish blue) from being exposed to high friction/heat.
midnyte
Suspension & Brakes
38
Jun 5, 2009 01:29 PM
2000Accord5sp
13
Sep 12, 2006 12:43 PM
WhitEdRift
Mar 11, 2004 08:48 PM
shipsaeki
May 29, 2003 07:48 AM
