1995 black rs acura integra part out >>>>>
Old Mar 27, 2008 | 10:16 AM
scrip2nite's Avatar
Default 1995 black rs acura integra part out UPDATED
ok, basically i purchased this 1995 integra rs 5 speed shell from a fellow ht member. I was going to use the front end,but decided to go a different route,so eveything else is up for grabs.. theres no swap....you can reach me at 1626 466 7563 or at h22a4typer@sbcglobal.net, and thanks for looking.
SIDE SKIRTS. SOLD.
ARMREST CONSOLE. SOLD.
CENTER SHIFTER CONSOLE. SOLD.
MASTER WINDOW DRIVER SWITCH .SOLD
DRIVERSIDE DOOR MOLDING. SOLD.
DRIVERSIDE DOOR SHELL. SOLD.
MASTER CYLINDER AND BRAKE BOOSTER. SOLD
PROP VALVE . SOLD.
PASSENGER DOOR SHELL. SOLD.
P75 ECU. SOLD
REAR TRUNK SHOCKS. SOLD
PASSENGERSIDE EXTERIOR QUARTER PANEL. SOLD
THROTTLE CABLE. SOLD
REAR BUMPER COVER. SOLD
PASSENGERSIDE QUARTER GLASS. SOLD
GLOVE BOX. SOLD
The following parts listed below are still available.....AND ALL PARTS ARE OEM ORIGINAL PARTS....
HOOD. SOLD
FRONT BUMPER. SOLD HAVE ANOTHER ONE IN WHITE,WILL NEED PAINTING.... SOLD
FRONT BUMPER REINFORCEMENT BAR.
DRIVERSIDE FENDER. SOLD
PASSENGERSIDE FENDER. SOLD
HEADLIGHTS. SOLD
RADIATOR CORE SUPPORT. SOLD
FRONT BUMPER LIGHTS. SOLD.
DRIVER AND PASSENGER DOOR GLASS.
DRIVERSIDE DOOR MIRROR IN BLACK.
PASSENGERSIDE DOOR MIRROR IN BLACK. SOLD
DRIVERSIDE WINDOW REGULATOR AND MOTOR.
PASSENGERSIDE WINDOW REGULATOR AND MOTOR.
CARGO COVER.IN BLACK. SOLD
REAR TRUNK PLASTIC COVER IN BLACK.
HORN. SOLD
HOOD LATCH. SOLD
HOOD LATCH CABLE. SOLD
HOOD HINGES.
HORN. SOLD
B18B1 LS ENGINE HARNESS. SOLD
DRIVERSIDE BUCKET RACING SEAT WITH RAIL.
KICK PANEL IN BLACK.
DRIVERSIDE DOOR PANEL IN BLACK AND GRAY.
PASSENGERSIDE DOOR PANEL IN BLACK AND GRAY.
E-BRAKE HANDLE IN BLACK. SOLD
ECU COVER PANEL. IN BLACK
DASHBOARD IN BLACK.
PASSENGER AIR BAG COVER IN BLACK, JUST LID COVER NO BAG. SOLD
SRS AIRBAG BRAIN.
SRS CLOCK REEL.
STEERING WHEEL.
CLIMATE CONTROL. SOLD
CLOCK.
DRIVERSIDE VENT
STEERING COLUMN.
IGNITION SWITCH WITH KEY.
UPPER AND BOTTOM STEERING WHEEL COVERS.
BLINKER SWITCH.
HAZARD SWITCH.
DEFROST SWITCH.
WIPER SWITCH.
DOOR SILLS IN BLACK.
SUN VISOR .
CARPET IN TAN COLOR.
SPEEDOMER CLUSTER. READS 170K.
CLUSTER TRIM IN BLACK.
CHARCOAL CANISTER.
PASSENGER WINDOW DOOR SWITCH IN BLACK.
DOOR HANDLE TRIMS.
FLOOR MATS OEM IN TAN COLOR. SOLD
REAR QUARTER PANELS IN BLACK. SOLD
WINDSHIELD WIPER BLADES.
POWERSTEERING HARDLINE.
POWERSTEERING RESERVOUR.
RACK N PINION.
COMPLETE FRONT DISC BRAKE CONVERSION. KNUCKLE ASSEMBLY. ( SOLD PASSENGERSIDE FRONT KNUCLE ASSEMBLY.)
COMPLETE REAR DISC BRAKE CONVESION. KNUCKLE ASSEMBLY.
REAR SWAY BAR OEM.
FRONT SWAY BAR OEM WITH ENDLINKS.
COMPLETE SHOCKS AND SPRINGS.ALL 4.WITH FORKS.
GAS TANK. SOLD
GAS PUMP. SOLD
REAR BUMPER REINFORCEMENT BAR.
REAR TAIL LIGHTS.
REAR TRUNK LID DOOR WITH GLASS.
FRONT SEAT BELTS IN TAN COLOR.
REAR SEAT BELTS IN TAN COLOR,
REAR SEAT BELT BUCKLES IN TAN COLOR.
FRONT SEAT BELT BUCKLE IN TAN COLOR.
REAR SEAT UPPER AND BOTOM IN TAN COLOR.
AIR CONDITIONER LINES,GOT MOST OF THEM.
CONDENSOR.
A/C DRIER.
A/C EVAPORATOR UNIT.
A/C CONDENSOR FAN.
HEATER CORE.
FAN BLOWER.
WINDSHIELD WIPER BOTTLE.
HEADLINER.
MAIN CABIN HARNESS.
RADIATOR. SOLD
RADIATOR FAN. SOLD
UNDERHOOD FUSE BOX.
HOOD HOLDER STICK.
CLUTCH,BRAKE GAS PEDAL.
MASTER CLUTCH CYLINDER WITH HARDLINES FOR AUTO TO STICK CONVERSION.
FRONT HARDLINE BRAKE LINES. FOR NON ABS CONVERSIONS.
LONG METAL PIECE THAT GOES ACROSS THE BOTTOM OF TAIL LIGHTS.
PASSENGER SIDE FENDER LINER. SOLD
DRIVERSIDE FENDER LINER.
RIMS AND TIRES. SOLD
Modified by scrip2nite at 8:37 PM 3/27/2008
Modified by scrip2nite at 8:38 PM 3/27/2008
Modified by scrip2nite at 8:17 PM 3/28/2008
Modified by scrip2nite at 5:29 PM 3/29/2008
Modified by scrip2nite at 8:54 AM 3/31/2008
Modified by scrip2nite at 8:55 AM 4/3/2008
Modified by scrip2nite at 8:33 PM 4/4/2008
Modified by scrip2nite at 10:15 PM 4/4/2008
Modified by scrip2nite at 10:15 PM 4/9/2008
Modified by scrip2nite at 10:42 PM 4/12/2008
Modified by scrip2nite at 10:14 AM 4/16/2008
Modified by scrip2nite at 9:49 PM 4/21/2008
Modified by scrip2nite at 9:50 PM 4/21/2008
Modified by scrip2nite at 9:53 PM 4/21/2008
Modified by scrip2nite at 9:58 PM 4/21/2008
Modified by scrip2nite at 10:00 PM 4/21/2008
Modified by scrip2nite at 8:42 AM 4/23/2008
Modified by scrip2nite at 6:13 PM 4/23/2008
Modified by scrip2nite at 11:14 AM 4/27/2008
Modified by scrip2nite at 9:22 PM 4/28/2008
Modified by scrip2nite at 10:17 AM 5/20/2008
Modified by scrip2nite at 9:19 AM 5/23/2008
Modified by scrip2nite at 4:57 PM 5/26/2008
Old Mar 27, 2008 | 10:50 AM
em1loc's Avatar
Default Re: 1995 black rs acura integra part out >>>>> (scrip2nite)
bummpp
Old Mar 27, 2008 | 10:52 AM
shillsdc2's Avatar
Default Re: 1995 black rs acura integra part out >>>>> (em1loc)
PMED!!!!
Old Mar 27, 2008 | 11:36 AM
scrip2nite's Avatar
Default Re: 1995 black rs acura integra part out >>>>> (shillsdc2)
pmed replied
Old Mar 27, 2008 | 11:42 AM
4cyl of thunder's Avatar
Old Mar 27, 2008 | 07:38 PM
scrip2nite's Avatar
Default Re: 1995 black rs acura integra part out >>>>> (4cyl of thunder)
Thanks for the
Old Mar 28, 2008 | 12:07 AM
blindsk8er1013's Avatar
hows the condition of the passenger seat and price? and how much for the steering wheel?
Old Mar 28, 2008 | 12:12 AM
shorsh's Avatar
can you pm me a price for the rear disk brake setup with e-brake cables, thanks!
Old Mar 28, 2008 | 12:16 AM
efrex's Avatar
Default Re: (shorsh)
Old Mar 28, 2008 | 01:18 PM
scrip2nite's Avatar
Default Re: 1995 black rs acura integra part out >>>>> (blindsk8er1013)
pmed replied on the passenger seat,and steering wheel...
Old Mar 28, 2008 | 01:19 PM
scrip2nite's Avatar
pmed you price on the rear disc conversion..
Old Mar 28, 2008 | 03:09 PM
em1loc's Avatar
Default Re: (scrip2nite)
bummpp
Old Mar 28, 2008 | 03:23 PM
shillsdc2's Avatar
Default Re: (em1loc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em1loc &raquo;</TD></TR><TR><TD CLASS="quote">bummpp </TD></TR></TABLE>
Old Mar 28, 2008 | 07:16 PM
scrip2nite's Avatar
thanks for the bumpzz
Old Mar 28, 2008 | 07:48 PM
Ramirez428's Avatar
you got pm
Old Mar 28, 2008 | 08:46 PM
scrip2nite's Avatar
Default Re: (Ramirez428)
pmed replied
Old Mar 29, 2008 | 01:58 AM
RecentlyAcquired's Avatar
damn i wanted to buy that shell
i just picked up a shell too... even though i shouldn't ask , how much for it?
Old Mar 29, 2008 | 07:17 AM
scrip2nite's Avatar
Default Re: 1995 black rs acura integra part out >>>>> (RecentlyAcquired)
should of bought it.. oh well at least you ended up buying one...
Old Mar 29, 2008 | 09:48 AM
shillsdc2's Avatar
Old Mar 29, 2008 | 04:28 PM
scrip2nite's Avatar
thanks
Old Mar 29, 2008 | 07:49 PM
Ramirez428's Avatar
bump & you have pm
Old Mar 29, 2008 | 11:49 PM
FlatBrokeHatch's Avatar
Default Re: 1995 black rs acura integra part out >>>>> (Ramirez428)
Do you still have the plugs for the front corner lights?
Old Mar 30, 2008 | 09:37 AM
scrip2nite's Avatar
Default Re: 1995 black rs acura integra part out >>>>> (FlatBrokeHatch)
pmed replied ,in regards the corner lights plugs
Old Mar 31, 2008 | 07:54 AM
scrip2nite's Avatar
Old Mar 31, 2008 | 02:54 PM
Ramirez428's Avatar
ttttt
