Tranny Shift Problem need advice
Old Mar 27, 2008 | 09:02 AM
ree21's Avatar
Default Tranny Shift Problem need advice
94 Accord DX 2.2 134,XXX miles
Okay I want to thank you guys for the advice with coolant in the tranny fluid. Turns out it was the radiator.
Now here's my second dilemma. I did a drain of the fluid couple days ago and everything was fine until last night. Car would engage then act like it was in nuetral. I'm thinking that I might need to drain it again or would a flush be recommended at this point because of the coolant.
Old Mar 27, 2008 | 09:40 AM
Hobbs94's Avatar
Default Re: Tranny Shift Problem need advice (ree21)
i would say check it make sure it is full and if it is make sure it isn't over full and u could try flushing but usually when u get to this point if it isn't a fluid level prob. the trans is usually toasted
97CWITR
Jul 18, 2011 08:05 AM
slideintegra08
Honda Civic (2001 - 2005)
Jan 5, 2011 10:19 PM
armintheman
Sep 19, 2010 10:56 AM
Wai
Oct 13, 2002 08:55 PM
