NEED HELP WITH MY CLUTCH
Old Mar 27, 2008 | 07:47 AM
SL0-hatch's Avatar
Default NEED HELP WITH MY CLUTCH
I HAVE A CIVIC HATCH CABLE TRANNY
MY CLUTCH IS EXTREMELY HARD TO PRESS DOWN
DOES ANYONE HAVE AN IDEA TO MAKE IT LESS HARD ??????
NEED HELP ASAP
Old Mar 27, 2008 | 09:05 AM
90efhatch's Avatar
Default Re: NEED HELP WITH MY CLUTCH (SL0-hatch)
try replacing your clutch cable.
Old Mar 27, 2008 | 11:51 AM
dr_latino999's Avatar
Isn't there an active filter to prevent folks from posting more than half in Caps? I know it's active in GDD.
Anyways, is this your first time on a cable clutch? I ask as I see the newer Civic as the avatar.
Old Mar 28, 2008 | 11:22 AM
SL0-hatch's Avatar
yea i jus got a ef but ive driven cable trannys before this ones jus really hard
Old Mar 28, 2008 | 03:08 PM
nitewolf's Avatar
Default Re: (SL0-hatch)
did u tighten ur cable urself, if so it might be too tight in other words ur clutch will go out fast.
Old Apr 21, 2008 | 12:28 PM
SL0-hatch's Avatar
Default Re: (nitewolf)
every time i loosen it, it makes the cable not able to pull the lever enough so i can't get it into gear. i tighten it and the clutch gets extremely hard and stiff and only then can i get it into gear...
bmxtrev
Transmission & Drivetrain
May 20, 2011 08:10 PM
Beeracer930
Apr 25, 2010 09:51 PM
hatchinprogress
Feb 15, 2006 10:22 AM
efrex
Nov 5, 2005 06:45 PM
