Anything to align before I pull my Dizzy
Old Mar 26, 2008 | 11:37 PM
new_climber's Avatar
Default Anything to align before I pull my Dizzy
As you may have already been able to see by some of my other question, this is my first Honda and for time with several things...so thanks in advance for all the help...
I am about to pull my tranny to install a new clutch...The manual I am using says to pull the dizzy for easier access to the tranny bolts. My question is, do I need to ensure anything is lined up before pulling the dizzy??? Or even more, when I put it back together..will the Dizzy just bolt back on...or is there something I need to ensure if lined up??
Thx again for all the help...this site is a wealth of information for newbies like myself
Old Mar 27, 2008 | 09:17 AM
90efhatch's Avatar
Default Re: Anything to align before I pull my Dizzy (new_climber)
There is nothing hard to removing and installing the dist. I would take and use a marker or something to mark where the top bolt goes in so you can put the dist back to where it was before removing it. That way it stays in time, If it was to begin with.
Old Mar 27, 2008 | 03:13 PM
SEATownboi08's Avatar
Yes take off dizzy, starter, unplug vehicle speed sensor which is right next to rear tranny mount. Disconnect any wires either near or on tranny. Take rear mount off, then do same for passenger mount but take out the bolts on the tranny first not the ones on the frame. Drain your tranny before you pull it off=P
accord99power
May 2, 2009 10:54 AM
accord99power
Transmission & Drivetrain
May 1, 2009 07:05 PM
cr-x si
16
Jun 19, 2003 09:13 PM
Heinz57
May 26, 2003 12:34 PM
type r 01-1063
Jul 14, 2002 08:11 PM
