Axle tranny seal, leaking after axle replacement,
I am about to pull my tranny and replace my clutch. I noticed that after I replaced my axles about 6 months ago, I have a small leak where the axle goes into the tranny. Is this seal easy to replace, or does the tranny need to be taken apart to get to the seal?? It is very small, but I figured it was be much easier to do this work with the tranny out...
Any suggestions are very much welcome.
Very easy, especially with the tranny out. They pop right out with a seal tool or even a screwdriver once the axles are removed. I used a bushing/seal installer tool to tap them back in flush with the flange. On my '91 Si, the seals were about $6 each aftermarket.
*Boostwerks*
19
May 3, 2006 09:20 AM
EJ1 wilcox
Jun 21, 2004 10:46 AM
AcCO12D95
Jan 8, 2003 09:07 PM
