95 Honda Del Sol Lagging!!!!!! need help!
Old Mar 26, 2008 | 10:07 PM
beaver619's Avatar
Default 95 Honda Del Sol Lagging!!!!!! need help!
ok i recently had a problem with my del sol..it wouldnt start..but it got it started...but now..when my car run it laggs..when it step on the gas it boggs..but when it catches speed..it runs fine..does anyone know what this can be!
Old Mar 26, 2008 | 11:27 PM
bcod151's Avatar
Default Re: 95 Honda Del Sol Lagging!!!!!! need help! (beaver619)
Have you had a tune up lately?
Old Mar 27, 2008 | 01:15 AM
hondatuning1989's Avatar
Default Re: 95 Honda Del Sol Lagging!!!!!! need help! (bcod151)
timing...?
Old Mar 27, 2008 | 01:14 PM
crazi_E's Avatar
Default Re: 95 Honda Del Sol Lagging!!!!!! need help! (hondatuning1989)
o2 sensor?
Old Mar 27, 2008 | 03:13 PM
beaver619's Avatar
Default Re: 95 Honda Del Sol Lagging!!!!!! need help! (crazi_E)
do u know where to get the ECL code from. my ECL light is on. that might be the problem but i dont know where to check for the code.
Old Mar 27, 2008 | 03:18 PM
crazi_E's Avatar
passenger side kick panel near the ecu
its a two wire plug that hangs down
stick a paper clip between the two connectors jumping them to contact each other and your CEL will flash
here is the FAQ's maybe itll help you understand better
https://honda-tech.com/zerothread?id=682412
DownShiftPerformDC2
12
Jul 13, 2011 06:57 AM
91sickness
May 31, 2011 06:49 PM
beaver619
21
May 18, 2008 10:10 PM
black95sol
Sep 28, 2007 11:29 AM
SiRSoL
Feb 13, 2002 08:20 AM
