Motor Mount help for B series EG
Old Mar 26, 2008 | 09:13 PM
blk007's Avatar
Default Motor Mount help for B series EG
I have B series swaped eg hatch. The problem is I didn't have the front lower torque mounts that stabilize the motor from rocking back and forth when I installed the motor. I only have the stock b series 3 mounts(driver side mount, tranny and rear mount).
The problem? The motor rocks too much for a stock motor. It drives me crazy. I want to slap my friend that told me it would be fine with just the 3 when I swaped the motor in. I would like to know what is the best way to stiffen up(not going super stiff like solid mounts or something that would make my teeth chatter..lol)?
Should I do DIY urethane my current mounts? ghetto hockey puck? Would Energy inserts for the 3 mounts currently in use make a difference? Should I get some after market not so aggresively stiff mounts like yonakas? they claim they use poly inserts but the ones i've seen are black. Any advice or opinions appreciated.
Note: It's hard to find the lower torque mounts and brackets and getting them from a honda stealership is most likely costly.
Old Mar 26, 2008 | 09:15 PM
95ProjectEJ1's Avatar
Default Re: Motor Mount help for B series EG (blk007)
So you are missing the mount that usually connects to the AC bracket and the lower trans?
Hit up the marketplace or go on...
http://www.slhondaparts.com
http://www.hondapartsdeals.com
Old Mar 26, 2008 | 09:16 PM
JEGD16Z6's Avatar
if it was me i would look into going to local junk yards and looking for some. they cant be more than 20$ at a junk yard.
Old Mar 26, 2008 | 11:02 PM
blk007's Avatar
Default Re: Motor Mount help for B series EG (95ProjectEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">So you are missing the mount that usually connects to the AC bracket and the lower trans?
http://www.hondapartsdeals.com</TD></TR></TABLE>
Yup, that's right. I need the little brackets that bolt on to the frame rails of the car also. All the stuff I need is on a 94+ teg.
ramboPandA
Jul 17, 2014 12:35 PM
b18 EK9
Mar 30, 2006 10:30 AM
AnitRiceSuperStar
Feb 21, 2004 11:39 PM
ForceFed Coupe
Dec 13, 2003 04:19 PM
