army green spray can paint job
i decided to paint my hatch army green and i'm using a spray can so before i paint the whole car i decided to try on the fender to see how it looks. what do u guys think about it, i need opinions
this is how the first coat looks like
after the first coat wet sanded with 800 grit put a second coat
and after second coat wet sanded with 1000 grit and spray the third coat
i still need to buff it and wax it
wow that came out amazing! I planned on rttle canning my whole car, but didnt expect that panels could be made as uniform as you have! Good job.
What kinda of paint are you using? Are you going to clearcoat over top? Had sanding between the layers made a major differance to the shine?
Hey post what materials you're using. That looks fantastic for a spray can job. My friend wants to do this same thing with his EG coupe and it would be great if his came out half as good as this!!!
how many cans did it take for that one fender? im guessing like half of a can?
did you sand it down to the metal before you put on the primer? did you primer?
if you clear coat it will it be shinny?
cuz my friend wants to paint his whole car. and he doesnt have money for a big paint job, so he should do this.
You're wasting your time sanding in between coats with 800/1000 grit. I would sand with 600 in between coats, then sand the final coat with 1000, then 1500/2000 if you're not lazy (like me).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matmcg »</TD></TR><TR><TD CLASS="quote">wow very uniform what paint is that?</TD></TR></TABLE>i would also like to know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matmcg »</TD></TR><TR><TD CLASS="quote">how much does each can cost , and did you sand or buff that fender</TD></TR></TABLE>
do you want to know what color underwear he was wearing when he painted the car?go to walmart and find out how much it costs
and if you read the first thread it told you, step by step, exactly what he did. he sanded and he STILL has to buff and wax it.
looks good man at my work we use rustolem all the time its good ****, being a painter i would advise primer or some sort of sealler ya feel me
Hey , I just went out and bought black tremclad rust paint gloss paint in a can and i sprayed up my rims looks really good!! it was really easy to do too so i guess spraying the whole car would be easy , really nice shine too
props for giving it a go and all, i dont think the fan a rattle can gives off is enuff for big areas such as pannels. i think youd be beter off doing the roller method even so that doesent give off the best finesh, will you be using a clear coat?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo. d »</TD></TR><TR><TD CLASS="quote"> will you be using a clear coat?</TD></TR></TABLE>i would also like to know.
