CRX GRS HOOD PROBLEM!!!!
Old Mar 26, 2008 | 05:45 PM
iNDiO's Avatar
Default CRX GRS HOOD PROBLEM!!!!
I recently bought a 89 rex with a gsr and i was told by a friend that if i swap the minifold, the hood will be able to close without loss of whp. if any one knows wat would be the best way for the hood to close w/ out loss of whp, i would realy appreciate the advice.
Old Mar 26, 2008 | 05:50 PM
Turbo Dan's Avatar
Default Re: CRX GRS HOOD PROBLEM!!!! (iNDiO)
subscribed
Old Mar 26, 2008 | 06:33 PM
grog's Avatar
SIR carbon fiber hood maybe
what manifold do you have? how much does it stick up?
I had to cut some of the webbing on the under side of the hood to clear my valve cover (hasport mounts) but I have always had a stock manifold.
Old Mar 26, 2008 | 06:39 PM
doublethink's Avatar
Default Re: CRX GRS HOOD PROBLEM!!!! (grog)
pretty sure the underwebbing trim job usually gets it done.
otherwise save your pennies and get a cf hood
Old Mar 26, 2008 | 07:36 PM
whiteknightef's Avatar
really wierd post!
Old Mar 26, 2008 | 08:55 PM
zrickety's Avatar
Default Re: CRX GRS HOOD PROBLEM!!!! (whiteknightef)
what would you swap the manifold to? you can stand eye-level with the fenders and get a good idea of where to trim the hood. it will probably be near the timing belt
Old Mar 26, 2008 | 10:18 PM
2slow4stock's Avatar
Wow.... What the hell are you trying to say... The hood will not cause ANY HP loss...
Just use spacers if it DOES NOT CLOSE.
Or
Are you trying to find another intake manifold to use in a crx?
Old Apr 3, 2008 | 12:56 PM
iNDiO's Avatar
Default Re: (2slow4stock)
i never said will the hood cause loss of whp, i asked will the manifold be an issue to loss of hp. the manifold that was put on my friends car was a Blox power manifold? so he says . also w/ hassport mounts
JustOneOrTwoPosts
Jul 19, 2011 05:21 PM
freedm
18
Jan 14, 2009 07:08 PM
98lude-t
Aug 22, 2005 01:25 AM
rhetorical
18
Sep 14, 2004 09:32 PM
GraphiteAccord
May 5, 2003 12:00 PM
