1990 honda accord
depends on what you call special. if you have nothing then it could be. you will need a 36mm socket, breaker bar, and a long steel/cast iron pipe of at least 48" long, the longer the better-more leverage, jacks, and good ole muscle. a second hand could help but not necessary. depending on your rims. you may have to raise the car to access the 36mm nut and then lower it to break it loose using the ground because you will spin the tires, then you will need to raise it back up again. i believe the fork bolt on the spindle is a 17mm, you will need two 17 wrench of some sort.
souljahboy808
Dec 15, 2003 07:27 AM
