benen fuel rail question
i received my benen fuel rail in the mail today.. i was looking at where the FPR hooks to it.. the middle hole doesnt go all the way through.. correct me if i'm wrong but do i drill that out?
same question here, mine is a bdl fuel rail, my hole for the pressure regulator does go straight tru but the other whole for like a fuel pressure gauge doesn't.. Am i suppose to tap it out? I've never bought an aftermarket fuel rail but i was force to when my oem one misteriously disapeared..
I'll try to post pics in a bit to help explain myself
hard to see but you can see that it is sealed, so if i put a gauge it wont read
the hole on far left is sealed off
What do i do? Try to Tap it out? how?
sorry this pic were taken by my phone
The hole between the two threaded ones needs to be drilled out. They do this so if you are running another form of regulator you don't have to block off the hole. Say a aeromotive,ect that would mount to the side of the rail, or have a line running to it off the side. Make sure you put the "O" ring under your regulator to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2wheelhunter »</TD></TR><TR><TD CLASS="quote">THE GUY... i had to tell you how much i love your sig
