Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
91 DI5 CIVIC (MOTOR SWAP)
Old Mar 26, 2008 | 10:35 AM
joescivic91's Avatar
Default 91 DI5 CIVIC (MOTOR SWAP)
Hi, I am new to this...I have a 91 civic and i wanted to upgrade the motor from a D15 to a v-tech.....If anyone has done a swap like this i could use your help on all the parts i will need and what i will need to change to get this done. It has a 5 speed manual trans. The motor and trans is out as we speek, need to get'er done by the end of this month......any ideas?? Thanks for helping
Old Mar 26, 2008 | 05:31 PM
dirty19's Avatar
Ridin Dirty in Cali
Default Re: 91 DI5 CIVIC (joescivic91)
What motor are you wanting to swap in to this thing???
A D16Z6 SOHC VTEC will fit right in no problem..Its the most easiest of all the G4 civic swaps. For this swap all you need is the engine, tranny, ecu, and axels....
If your looking at the DOHC VTEC you'll find that you will spend more money.
You can put in anything from a B16A1 (Del Sol) all the way up to a B20 out of a Prelude Si
These swaps usually take a motor mount kit and maybe some extras... Hasport and Place Racing have kits for these kinds of swaps.
Do your research first.. know what you want. Check the Tech section I'm sure you'll find more there.
vtville
Nov 26, 2009 11:15 AM
joescivic91
Mar 26, 2008 11:09 AM
StillPullinVtec
Dec 5, 2007 12:03 PM
CBennyR600RR
Jun 7, 2005 11:47 AM
