water spots on mycf hood
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_teg04 »</TD></TR><TR><TD CLASS="quote">buff and polish
Better take care of that before you have to sand them out...
Sanding c/f sucks.
</TD></TR></TABLE>Better take care of that before you have to sand them out...
Sanding c/f sucks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GuNnErGoD »</TD></TR><TR><TD CLASS="quote">Clay bar isn't designed to remove water spots, only surface contaminants.</TD></TR></TABLE>
thats what water spots are. minerals from water, dried out on the surface
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by welfarepc »</TD></TR><TR><TD CLASS="quote">
I've never been able to take off water spots with a clay bar. That's because water spots aren't loose contaminates 'stuck' to the clear. They're hard water stains on the clear and depending on how long they've been there, they bond to the clear and build up and get thicker and taller. That is why wetsanding is sometimes neccessary in their removal.
A clay bar would be useless unless the water spots are only hours old at the most. Of course, you could remove them with a rag at that point.
</TD></TR></TABLE>I've never been able to take off water spots with a clay bar. That's because water spots aren't loose contaminates 'stuck' to the clear. They're hard water stains on the clear and depending on how long they've been there, they bond to the clear and build up and get thicker and taller. That is why wetsanding is sometimes neccessary in their removal.
quicksol95
Mar 18, 2006 10:02 AM
Nocturnal
Jan 22, 2005 05:32 PM
