Where is main ground for horn, brake lights, and shifter lock?
Old Mar 26, 2008 | 08:28 AM
Cee_mon's Avatar
Default Where is main ground for horn, brake lights, and shifter lock?
I have checked all fuses, and made sure the bulbs all work. Iam gonna be testing the brake switch tonight, But i am told to check the main ground as all 3 things might ground out the same way. Does anyone knows where this 1 ground might be?
Thanks in advance
*EDITED*
Car is a 92 dx hatch
The problem that is been happening off and on for 1 week now is I lose my horn, brake lights, and my shifter wont release to get out of park. Now the problem has been 1 straight day without anything working. I have checked the ground in the hatch as well as the one of the back of the car under where the hatch is. All fuses have been checked aswell. I am gonna pull off the bumper once i get some light outside and check the power/ ground going to the horn. I have a spare brake switch that i can install if needed, but wanted to see the easy options first.
Thanks
Modified by Cee_mon at 5:46 PM 3/26/2008
Old Mar 26, 2008 | 08:48 AM
philosofy1's Avatar
Default Re: Where is main ground for horn, brake lights, and shifter lock? (Cee_mon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cee_mon &raquo;</TD></TR><TR><TD CLASS="quote">I have checked all fuses, and made sure the bulbs all work. Iam gonna be testing the brake switch tonight, But i am told to check the main ground as all 3 things might ground out the same way. Does anyone knows where this 1 ground might be?
Thanks in advance</TD></TR></TABLE>
what exactly is going on?
Old Mar 26, 2008 | 09:43 AM
Frozen E's Avatar
H-T White Ops
FWIW, the horn casing is it's ground. The wire going to it sees power when you hit your horn button.
Old Mar 26, 2008 | 02:45 PM
Cee_mon's Avatar
Default Re: (IslandSi)
Sorry for being vague, i was on work time when i posted.
Thanks
oohtruck
Sep 17, 2012 08:46 AM
easy_vtec
21
Sep 8, 2011 02:07 PM
nikesbdude
Feb 13, 2009 12:43 PM
SOHCVTECx2
Jun 20, 2006 09:54 PM
puppetmstr80
Aug 26, 2005 11:43 PM
