slow car!!!
Old Mar 26, 2008 | 07:07 AM
driftam1's Avatar
Default slow car!!!
theres someting wrong with my engine its redline is a about 4k rpms well thats wat the tach says any ideas ? also my first gear goes upt to 35-40 mph and secound goes to75 very slowly 0 to 60 n bout 18 seconds !!
Old Mar 26, 2008 | 08:31 AM
hondasaurusrex's Avatar
Default Re: slow car!!! (driftam1)
probably a problem with your distributor...check your codes its most likely a bad crank position sensor...also knowing what car/engine/obd your using helps a LOT when you ask vague questions like that....
Old Mar 26, 2008 | 08:52 AM
driftam1's Avatar
Default Re: slow car!!! (hondasaurusrex)
ok car ef hatch engine stock d15b i checked the distritor its fine also im burning oil so what should i check next? also how do you check the ecu codes?
Old Mar 26, 2008 | 09:05 AM
driftam1's Avatar
also it used to be an 4spd trany and i changed it to a 5 cause the second gear in the 4spd was bad would that have anything to do with it?
Old Mar 26, 2008 | 09:19 AM
mf-doom's Avatar
also check your timing it may be off
Old Mar 26, 2008 | 09:51 AM
wiZCo's Avatar
Stouts 'n' Scotch
Your car is in limp mode because you have an engine code. Pull the code from your ECu and report back.
Old Mar 26, 2008 | 10:07 AM
driftam1's Avatar
Default Re: (wiZCo)
how do u pull the code?
Old Mar 26, 2008 | 10:11 AM
driftam1's Avatar
i check ecu and the red dot is flashing?
Old Mar 26, 2008 | 10:13 AM
driftam1's Avatar
ok it the red light flashes 10 times and then stops and the starts again?
Old Mar 26, 2008 | 10:14 AM
wiZCo's Avatar
Stouts 'n' Scotch
Yup. Count the number of flashes and that's the code. A long flash is 10, short flashes are 1, add them up for the code. There will be a slight pause between codes if there are more than one.
Old Mar 26, 2008 | 10:17 AM
wiZCo's Avatar
Stouts 'n' Scotch
Code 10 = Intake Air Temp sensor, it's on the passenger's side of the intake manifold, it has two wires running to it ( I forget the colors).
Test the sensor and wiring according to the specs in the CRX workshop manual (if you don't have one, download it from the link in the FAQ).
Here's a link to engine codes: https://honda-tech.com/zerothread/1710584
Old Mar 26, 2008 | 10:20 AM
driftam1's Avatar
Default Re: (wiZCo)
is it the sensor that has the two screws and i think a red and a yellow wire it broke i have it getto riged cause the screws woln't come off to tight but wat would have to do with power or acceleration?
Old Mar 26, 2008 | 11:01 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (driftam1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by driftam1 &raquo;</TD></TR><TR><TD CLASS="quote">is it the sensor that has the two screws and i think a red and a yellow wire it broke i have it getto riged cause the screws woln't come off to tight but wat would have to do with power or acceleration?</TD></TR></TABLE>
That's the one. It tells the ECU the temperature of the air coming into the intake manifold so it can adjust fuel maps and set idle speed correctly. You need to un-ghetto rig it or else you won't be able to rev past 3200RPMs. Period.
Let this also be a lesson to you that ghetto-rigging anything on your car is a bad idea.
You should be able to snag a new one from a junkyard or in the parts thread at the top of the page.
Old Mar 26, 2008 | 11:08 AM
driftam1's Avatar
Default Re: (wiZCo)
yea i got 1 from the junk yard i had to getto rig it to get to the junk yard lol the only problem is that the screws wolnt come off any ideas? like ?
Old Mar 26, 2008 | 11:43 AM
traxxasx's Avatar
lol my ef 5th gear takes me to 45mph.at 3k
Old Mar 27, 2008 | 06:31 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by driftam1 &raquo;</TD></TR><TR><TD CLASS="quote">yea i got 1 from the junk yard i had to getto rig it to get to the junk yard lol the only problem is that the screws wolnt come off any ideas? like ?</TD></TR></TABLE>
PB Blaster + an impact driver. If that doesn't work, you may have to drill them out and re-tap.
smokey68321
27
Nov 16, 2009 06:03 PM
jdmazm
Apr 21, 2005 07:58 PM
AGPSuperstar
May 14, 2003 01:56 PM
BigMig
May 10, 2003 06:01 PM
akirax
May 2, 2002 08:36 PM
