JDM Front end question.
I was wondering, do i need the radiator support that came with my front end clip in order for the hood, fenders, bumper, filler, and t-bar to fit perfectly?
When i say the radiator support its the skin that is connected to the frame.
Thanks.
Thanks.
no you dont, sometimes when you get a front end they will send you different types of t bar which will cause your hood not to shut but thats the only thing you will have to fix.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9robert »</TD></TR><TR><TD CLASS="quote">Thanks, just checking. So i can probably sell this support i have :-)
thanks.</TD></TR></TABLE>...there are 2 diffrent t supports......the one that came on the sir models....are the same as the usdm......the only diff is that the jdm one has the lil cut out for the filter resonance/intake.........the other one came on non vtec models with the sir front end...that is the bar that u need in order for everything to be bolt it........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89hatcher »</TD></TR><TR><TD CLASS="quote">will the ef8 one work on the ef9 front also?</TD></TR></TABLE>
there is no difference they are the exact same part
