Classic Hondas All Pre-1988 Hondas.
need help with an 87 civic hatch si
Old Mar 25, 2008 | 10:15 PM
HUSTLER5s's Avatar
Default need help with an 87 civic hatch si
how do you lower the front. can a motor swap be done. and a good place to get performance parts
Old Mar 26, 2008 | 07:16 AM
cbstd's Avatar
Default Re: need help with an 87 civic hatch si (HUSTLER5s)
Welcome!
You need to go to http://www.redpepperracing.com for the answer to all your questions. Read the FAQ section and then post specific questions. There is a lively 1st Gen CRX/3rd Gen Civic (basically the same car under the sheetmetal) community here in SoCal.
Scott
Old Apr 1, 2008 | 07:47 PM
olskoolrex's Avatar
to lower the front there are two bolts in the tortion bar and when you loosen them they will lower the front its pretty easy did it to mine as for swaps it can be done. I have a b16 in mine but it did run me a good amount of money. I went through hasport for alot of my parts that i needed. i hope this info kinda helps
Old Apr 8, 2008 | 09:50 AM
HUSTLER5s's Avatar
so how far are you able to lower it with the torsion bar bolts
Old Apr 8, 2008 | 11:47 AM
E-AT_me's Avatar
about an inch. then you can take the tubes off and re-index the bars to however low you'd like.
Old Apr 8, 2008 | 12:52 PM
HUSTLER5s's Avatar
Default Re: need help with an 87 civic hatch si (E-AT_me)
what do you mean by re-index the tubes please do explain
Old Apr 8, 2008 | 07:23 PM
silentdork818's Avatar
Default Re: need help with an 87 civic hatch si (cbstd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cbstd &raquo;</TD></TR><TR><TD CLASS="quote">Welcome!
Scott</TD></TR></TABLE>
I never see any 1g/3gs around here.
Old Apr 8, 2008 | 08:12 PM
icebox187's Avatar
redpepperracing.com
onegvtec.com
look on redpepper for the kakabox thread. or i think indexing may be in the wiki as well
CRX EF 88
12
Feb 20, 2008 05:54 AM
540i6
Jan 20, 2005 11:34 AM
vg30dett71510
Jan 9, 2003 04:32 PM
knightnam
Sep 14, 2002 08:06 AM
