EG/h22 cooling system questions....sorry :P
I want to check out the radiator/fan clearance issues because I'm ready to start picking up some parts.
so far I have:
Del Sol VTEC radiator. 12" slim fan puller style (why puller though?)
and a 12" slim puller style again for the a/c. (again, why puller?)
I've heard that i will have to mount both of these fans IN FRONT OF the radiator/condensor, between the radiator and the front bumper. Is this true? Wouldn't that block too much airflow? and if I instead put the fans where they would normally be, would i make them a pusher style?
will this get me set for the cooling system? Any pics would be greatly appreciated (especially if you show me exactly what you're using
so far I have:
My friend had a lude/vx, he used the stock vx radiator and a narrow puller fan. With no cooling problems ever. You need the narrow fans for front motor mount clearance. You need a puller because your supposed to put it behind the radiator, like it is stock, and let it pull the air through. Rather than a pusher which would go in front.
chewiejdh
Jun 29, 2003 04:36 PM
